reclaimed wood?
Micah Covington
reclaimed wood?
Post by Micah Covington »
A friend has some property with the remains of an old barn. He didn't know what to do with it. I found many pieces of pine which had been sitting for over 60 years. They were just thrown in a pile, but are straight and show no signs of warping. They are incredibly dry, and have checked quite a bit. They are also the hardest pine i have ever encountered. I was thinking of using these for a solid body or the wings of a neck through. Is there anything I can use to fill the cracks? Is this wood usable? Am I crazy for even trying?
Re: reclaimed wood?
Call it what you like - recycled, reclaimed, reused, "seasoned" - if it's falling apart, then it's just plain old and decaying. Find pieces that do not have significant cracks and checks, pull out all the metal, run em through a planer or sander to get down to some clean(er) wood, and make a better assessment. Generally speaking, cracks are to be avoided in instrument construction.
Re: reclaimed wood?
Hi Micah,
You can fill the cracks with epoxy. For a solid body guitar structural integrity is the main concern, so as long as the wood is "solid" you should be fine.
Matthew Lau
Re: reclaimed wood?
Post by Matthew Lau »
Dude! Nice score.
I prefer using salvaged wood myself, because the quality of wood back then was often far superior to what we have now (for the same species).
Same rules apply: go for clear, stable wood that's not cracked or falling apart.
Jason gives good advice.
