confounding buzz
confounding buzz
Postby Robert Smallwood » Fri Jan 19, 2018 11:39 pm
Hi.
I have a strat with a wilkinson trem which I made some time ago.
The E1st string has developed a rattle all the way up ie on each fret , from about fret 10 and it even buzzes loudly on the very last fret. The string is not touching the end of the neck or the pickups.
I have put plumbers' tape around every grub screw and thread I caN find gone up & down the neck with 600 grit , a stewmac fret rocker files etc etc - ie there are no high frets underlying the E 1st string. As far as I can tell the frets are seated well.
I'm not sure where to look next.
I think this has come on over time and indeed i'd swear on some days it's worse than others but that's a little subjective.
Can anyone give me some clues and ideas on identifying the basic issue and fixing it please?
All advice welcome.
Rob.
Robert Smallwood
Re: confounding buzz
Postby Gordon Bellerose » Sat Jan 20, 2018 1:34 am
Ah.... the elusive buzz.
First of all place your hand on every piece of hardware while you're plucking the string.
Secondly tighten every screw.
I am assuming you have tightened everything on the bridge itself, thus eliminating that possible source.
It could be a saddle with a rounded edge or a sharp groove worn in it. Or a loose fitting trem handle.
It could also be the truss rod, although that should buzz with every string.
It could also be coming from a loose piece on a tuning head, or a string retainer.
If all that fails try changing the string.
