cello broken neck
Steven Wilson
Re: cello broken neck
Post by Steven Wilson »
Thanks Michael
The button on the back separated easily. That's where I would normally apply pressure while steaming the joint. I'm wondering how to get a hold on it to pull the heal.
Thanks
Steven
Again, I suggest you get the Shipman-Weisshaar book.
A typical method for the violin family neck removal is to carefully saw a narrow kerf next to the heel and force the heel to the side to break it out of the mortise. A shim is used to fill the extra space when the neck is re fitted so the joint is snug. For this method I would use a block that fits the length of the heel, and a hammer. I would start with a sharp blow on each side to help break the glue joint. More hammer only as needed.
Without knowing the type of glue used on this instrument I hesitate telling you to use steam.
Soft wood is a real problem because it isn't strong enough in the first place, it can be difficult to repair, and the repair is still questionable.
Steven Wilson
Thank you Michael
I can't see $325+ for the book but understand your suggestion. I have the heal lose and will post my progress
Jim McConkey
Post by Jim McConkey »
The original suggestion was to ask your local library to get the book for you on inter-library loan. Most public libraries will do that for little or no money.
Not much gets by you does it Jim? <G>
