Forum down for upgrade 1AM CDT May 1
Postby Charlie Schultz » Tue Apr 30, 2019 11:03 am
Hi all,
We're upgrading our server at 1 AM CDT on May 1. Hopefully it will just be an hour or so and should be transparent. However, you can check our Facebook page for status updates if things don't go right, https://www.facebook.com/MIMForum/
Re: Forum down for upgrade 1AM CDT May 1
Postby Chuck Tweedy » Tue May 07, 2019 10:02 am
Charlie - we lost the favicon.
Postby Beate Ritzert » Tue May 07, 2019 6:33 pm
When i try to view a list of my own posts i am getting the following error:
SQL ERROR [ mysql4 ]
Expression #1 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'mimf_phpb437.p.post_id' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
Beate Ritzert
Postby Charlie Schultz » Wed May 08, 2019 8:10 am
Favicon should be back now. I'm looking into the SQL errors.
Postby Chuck Tweedy » Wed May 08, 2019 5:09 pm
it be back! my life was rocked without the tiny yellow guitar!
I never realized that it is a cutaway!!!
