Frankenstein Mando-Cello
Postby Greg Steil » Wed Aug 31, 2016 9:25 am
Dear Hive mind, one of my on again off again projects is converting an old Harmony arch-top to a Mando-Cello. Problem one...a soft Maple fingerboard that was stained Black, and now I have it sanded down to re-fret, there are still splotches of stain. What would you suggest to re-stain a nice dark Black? Problem two....Tail piece? I'd like to keep the "trapeze" style. I have the original. Any ideas for modifying it? Many years ago, I inlayed a steel bar in the neck, and sorta bolixed up the job, so cosmetics will involve Black laquer for sure. Thanks in advance for any ideas!....onward through the fog!
Greg Steil
Re: Frankenstein Mando-Cello
Postby Clay Schaeffer » Sun Oct 02, 2016 8:22 am
Mohawk makes a black ultra penetrating stain that can be used to directly dye wood and also mixed with lacquer (and other finishing materials) to make black lacquer. I believe it costs about $22 -25 a quart (which can dye a lot of material).
With the tail piece you may want to use the two outside holes and drill a couple of new ones for the middle strings. Is your mando cello 4 strings or eight? I have made some guitar bridges that could be strung with six strings or 4 pairs.
Sounds like a fun project!
Postby Mark Swanson » Mon Oct 03, 2016 9:09 am
I just worked on one of those Harmony guitars that had the soft maple fingerboard. I cursed it loudly a few times, that fingerboard was crap. If it was my guitar, I thought it would improve a whole bunch in tone and structure if I made a new fingerboard for it.
