Electronic violin
Electronic violin
Postby F murtz » Mon Apr 04, 2016 5:02 am
Having got this far, any suggestions for a shoulder rest?
F murtz
Re: Electronic violin
Postby JC Whitney » Mon Apr 04, 2016 7:43 pm
Disclaimer - I don't play violin, don't own one, and have never made one.
With that said... how about two dowels sticking out perpendicular from the flat spot between the tuners and the end, supporting a comfortably contoured kidney bean-ish shaped shoulder rest? Maybe removable so it still packs up nice and small?
JC Whitney
Postby David King » Mon Apr 04, 2016 11:22 pm
I've always used a "Kun" shoulder rest and I'd figure out a way to adapt one of those if it were to be my instrument.
Postby F murtz » Mon Apr 04, 2016 11:49 pm
JC Whitney wrote:Disclaimer - I don't play violin, don't own one, and have never made one.
That is my problem till now, have made a strum stick and half made a mandolin.
I saw someone had made a violin from a bit of 2x4 so I thought I would give it a go but he did not say much about rests.
F murtz
Postby Beate Ritzert » Tue Apr 05, 2016 8:29 am
David King wrote:I've always used a "Kun" shoulder rest and I'd figure out a way to adapt one of those if it were to be my instrument.
My Yamaha SV120 violin uses a modified Kun shoulder rest in the size for the smallest violins. But also that one will not fit easily on Your instrument unless You add a plate to mount it. You might search the net for pictures of that instrument.
Another approach is to add an "anchor" shaped extension to the body that has the size and curvature of a standard instrument and gives the player the freedom to chose the rest he or she usually prefers. The shoulder rest is a fairly individual choice, and IMHO that freedom of choice should not be taken away from the player.
Another remark: unless the player explicitly wishes something different it is wise to follow the traditional shaping of the neck. It helps with the orientation on the instrument.
Beate Ritzert
