Single fret buzz Mystery
Alexander Higgins
Post by Alexander Higgins »
Got my Hybrid Steinberger bass all assembled, sounds great except for 23rd fret on the G string, which "frets out" with an anemic buzz like a reluctant fart. The 22nd fret has a tiny buzz and 24th no buzz at all. I can't see any evidence that any of the last three frets have lifted, and since it's a carbon graphite neck, i know the neck hasn't moved in this century. Raising the string height to any reasonable action doesn't cure it. I don't own a fret rocker, should I try the Credit Card trick? Suggestions? It never did this while it was attached to the original Steinberger body, so something has changed, but why just one fret?
Re: Single fret buzz Mystery
You can make a fret rocker out of anything. Just get it flat, I made mine out of some aluminum stock that I sanded flat on a good flat surface. So do that, and look to see if there is a high fret. This can also be caused by a loose fret, when the string is played on the loose fret is is not seated well and deadens the tone.
Steve Benford
Post by Steve Benford »
Alexander Higgins wrote:Got my Hybrid Steinberger bass all assembled, sounds great except for 23rd fret on the G string, which "frets out" with an anemic buzz like a reluctant fart. The 22nd fret has a tiny buzz and 24th no buzz at all. I can't see any evidence that any of the last three frets have lifted, and since it's a carbon graphite neck, i know the neck hasn't moved in this century. Raising the string height to any reasonable action doesn't cure it. I don't own a fret rocker, should I try the Credit Card trick? Suggestions? It never did this while it was attached to the original Steinberger body, so something has changed, but why just one fret?
This is a shot in the dark but, are all of your neck bolts fully tightened down? Ive forgotten to snug them up once on a guitar and it caused the end if neck to flair up a tiny bit causing the same type of buzzing your having. Also, double check that your neck screws are not to long. The lowest ones may be pushing the FB up slightly from underneath.
Just a couple ideas! Good luck!
STEVE
