How do I fix a loose nut
Ron Daves
Post by Ron Daves »
The nut I have for the guitar I am building is about two playing cards thinner than the slot. What's the best way to fix this?
Frustrated luthier wanna-be
Steve Senseney
Re: How do I fix a loose nut
Post by Steve Senseney »
Stick in 2 playing card thick pieces of paper. You can leave it loose or glue it in.
If you want it to not show, buy a piece of bone from the pet shop, and cut a new nut that is a little thicker. You can also make nuts out of wood (generally the harder the better) corian, and other various materials.
I personally think bone is best for a guitar.
Nick Middleton
Post by Nick Middleton »
You could also fill in the gap between the nut and the headstock with matching-wood
Brian Dyskin
Post by Brian Dyskin »
+1 to adding matching timber - This one was done like that on purpose.
nut with matching timber laminations
John Hamlett
Post by John Hamlett »
I'd just make a new nut, throw the one that doesn't fit in the drawer and hope something comes along that it will fit.
Patrick Hanna
Post by Patrick Hanna »
All of these suggestions are valid. It depends on how fussy you are about appearances and how creative you are with things like wooden infills. You could even compromise. Fill it with strips of cards or veneer strips and play it that way until a new, thicker nut blank arrives in the mail. I'm serious.
Ron Daves
Post by Ron Daves »
Patrick. Okay, thanks for the suggestion.
Arnt Rian
Post by Arnt Rian »
I always do what John suggested, whenever I file the slots too low, the nut too small, whatever. It doesn't take that long to make a new one, once you get into the habit...
Ron Belanger
Post by Ron Belanger »
Best to make a new one. Keep the existing one and make the nut slot on your next instrument a little narrower
