After much research and debate along with advice Nicholas Blanton and the great folks over at everythingdulcimer, I have started my first HD. It will be a 17/17 with a glued top based on Deb Suran's plans (#39 GAL http://www.luth.org/plans/instrument_plans.html#plan39 ).
I started with the pin blocks. To be honest I had to toss the first pair I made because I tried to cut the slots for the rails on the table saw. The second time I used the band saw to cut in from the end and it worked much better. It was probably a good thing I messed up that because it gave me two pieces to test drilling for the pins. Finally settled on this. The tops of the pin blocks are beveled at 15° so I set the table on the drill press table at 18° to make sure that the strings stayed down. Then I set the fence at 34° (the angle of the pin blocks) off axis. I glued a full template of the pin locations to the pin block to keep everything in the right place (I hope). I used a piece of 1/4", 1/2", and 3/4" plywood to space out the four rows of pin holes.
Then I got to thinking about carrying this thing around and decided that since I had overbuilt it I should remove a bit.
While I was thinking about how to drill all those holes, I decided to work on something simple...the bridges. The first one (bass) was a piece of cake, but it took four tries to get the treble bridge done.
Here's a shot of the frame being glued up. Extra bonus points if you can figure out what those doors are off of.
While that was drying, I took care of the bridge braces.
Next I cut and fitted the bottom (marine grade Okoume 1/4" ply) and glued it up. (BTW that isn't a gap on the left corner but a shadow from where the short rail is a little proud).
Then I glued up the top.
Well that's as far as I got this week. I'll post the rest of it next week (God willing).
Building my first Hammered Dulcimer
Re: Building my first Hammered Dulcimer
Here's an update...
Glued in the bridge braces and the laminated block for the leg insert.
Here's a close-up of the block.
Just to be safe I ran a couple of oak dowels into it.
Trimmed up the bottom and added a hand hold along the long rail.
That big gash has me a bit ticked!
Finally, I cut and fitted the top.
Tomorrow I'll cut the sound holes and glue the top down. I spent most of today testing the idea of using hole cutters to cut the sound hole and the lip for the rosette. The 2-1/8" one is a bit too small and the 2-1/4 one is a bit too big. Tomorrow I will try to cut a test lip with my new router (It is amazing how much better they cut with good bearings in them ). If I don't like the way that works, I will use the hole saw and fill the gap with ebony sawdust. Almost there!
- Jon Whitney
I don't think they are from a DeLorean or an A/C Cobra, despite having the look of aluminum. Maybe it's just the lighting. I would guess an old Ford Bronco.
Oh, and the HD looks nice too.
Old yes, but not domestic.Jon Whitney wrote:Extra bonus points if you can figure out what those doors are off of.
And thanks, I should be doing the finish this week.
OK here's where I'm at with this.
I got the holes for the rosettes cut with the router. They are a press fit which is good because I know I am going to want to put pickups in this at some point. That way I can hopefully pull the out to install the pickups without messing anything up. then I glued down the top.
Then I glued up the at least 75 year old walnut for the caps on the rails. I inherited this stuff from my Grandfather along with most of the tools that use. It is special to me to have something that was his in this dulcimer. You can't see it in the pictures but the wood is a little bit spalted.
While that was drying I drilled the holes for the legs.
And installed the inserts. They are press fit with a little epoxy and a screw to keep things together. I really hope this holds up
Then it was just a matter of two days of sanding to get it ready for the finish. Oh yeah and I built some hammers too.
The long rail cap is made of four pieces bookmatched, but I didn't like the way the grain matched up in the middle so I added a piece of ebony left over from my first build (a Steinburger "V" that I never finished). That is the same ebony I used for the hammers.
The short rail cap is just bookmatched.
Visually this turned out very nice and I have a feeling that it is going to sound good also as it has a very sweet tap tone.
Now "all" I have to do is the finish and string it Oh yeah and build and install the dampers...we're almost there!
Done! 8)
Got the finish done I choose to use satin urethane because I am familiar with it. I followed that with a couple of coats of paste wax.
Then it was time to string it up. I have to tell you that by the time I had it strung up, I was ready to string it up As my dimensions were very close to Sam Rizzetta's Extended Range, I used his string gauge chart. This uses a lot of phosphor bronze which I have learned to hate as it breaks very easily. I think I threw away almost as much of it as ended up on the dulcimer. I also had fits with the loops slipping and ended up soldiering all of them.
However, I think it was all worth the effort as I ended up with an instrument that matched the tone in my head (very warm and sweet with a ton of sustain).
The legs worked out very well.
And when they are off there is nothing hanging off the bottom.
Heart felt thanks to Nicolas Blanton for all the help in designing this. You are awesome!
- Charlie Schultz
- Site Admin
Nice work Ken! I bet it sounds good too- I built one from Deb's plan years ago and folks always liked its sound.
Thanks Charlie, it does sound great but I found that the low treble course (B3/E3) was a little wonky using a .025 Phosphor Bronze string. I put a .030 wound string on and it sounds much better. I also have one pin that seems to be slipping that I may have to pull our and add some monofilament line to, but that one is also PB and I am out of that. So I guess that I need to make another wire order to make sure that I have spare strings and get the wound wire off of the treble bridge.
