relief on violin fingerboards
Postby Anders Eliasson » Wed Mar 07, 2012 4:40 am
Is it normal to make a small relief on the fingerboard of a violin and i this case how much?
Anders Eliasson
Re: relief on violin fingerboards
Postby Chet Bishop » Thu Mar 08, 2012 4:24 pm
When I press the string to the board on both ends simultaneously, thus making the string a "straightedge", I expect to see approximately the diameter of the string underneath the string itself. Probably there are more sophisticated ways to approach it. The center of that scoop is not in the center of the board, but slightly south. Maybe there is a precise measurement somewhere....
Chet Bishop
Violin-family instruments
Forest Grove, Oregon
Chet Bishop
Postby Anders Eliasson » Fri Mar 09, 2012 2:34 pm
Thanks Chet. No nead for precise measurements. I fully understand your description. When making the relief on the Spanish guitars that I build, I dont meassure, but I know what I want.
Anders Eliasson
Postby Barry Guest » Sun Apr 01, 2012 6:54 am
The conventional thinking is .03 inches or three quarters of a millimeter under the "G" at the neck stop diminishing progressively to a quarter of a millimeter under the "E" at the neck stop. Personally, I don't think that it is necessary at all. A fingerboard/neck made perfectly straight will always have some natural relief under the tension of the strings, even if undetectable by the naked eye.
Alumnus of Wood and Strings
Barry Guest
Postby John Fabel » Wed Apr 04, 2012 7:16 pm
I was taught similar to Barry. ("Make it look like this" were the precise instructions, and believe me, it had to look EXACTLY like that). Player preference will sometimes influence, also. My favorite tool for this is the little Lee Valley "Apron" plane, SHARP blade.
JF
John Fabel
