Question:Modify a neck from 43mm to 41.3mm
Postby Soultribe » Sun Jun 10, 2012 9:00 am
Hi, a question . Possible to modify a 43mm 1 11/16 nut width neck to 1 5/8?
Seriously doing to a ibanez neck thks
Soultribe
Re: Question:Modify a neck from 43mm to 41.3mm
Postby Greg Robinson » Sun Jun 10, 2012 1:41 pm
Hi Soultribe,
Please note that we require the use of real full (first and last) names on this forum, and do not accept aliases or "handles". Please let us know your name here or in a private message so that we can update your registration and login details for you (you are not able to make these changes yourself).
Thanks.
Greg Robinson
Postby Jim Ashby » Mon Jun 11, 2012 3:44 am
11 thousandths of an inch? Is it worth it?
Jim Ashby
Postby Rodger Knox » Mon Jun 11, 2012 3:50 pm
Yes, you can do it, and it will be a lot of work. Will you notice the difference? Maybe, but probably not.
Are you going to change the string spacing as well?
Rodger Knox
