Paul Gransee's 7th Bass
Postby Paul Gransee » Wed Apr 18, 2012 10:38 pm
Hi all first time on the new forum hope this works. This is my seventh bass a 5 string with a myrtle front and back. I used ebony for the fret board and simplified the inlay.
Paul Gransee
Re: Paul Gransee's 7th Bass
Postby Paul Gransee » Wed Apr 18, 2012 11:10 pm
Front view
Paul Gransee
Postby Jim Bonnell » Wed Apr 18, 2012 11:12 pm
Great job Paul. Anymore pictures. I'm working on my first bass along with several other projects. I can't seem to keep it at one at time.
Jim Bonnell
Postby Paul Gransee » Wed Apr 18, 2012 11:17 pm
Thanks Jim I'm trying to add photos but it wont let me, I will keep trying.
Paul Gransee
Postby Jim McConkey » Thu Apr 19, 2012 3:20 am
There is a temporary Forum-wide problem preventing anyone from uploading images. Please be patient. It should be fixed soon.
Jim McConkey
Postby Paul Gransee » Thu Apr 19, 2012 11:12 am
The back view both the front and the back are myrtle.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:14 am
A close up of the head stock which is faced with chechen.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:16 am
And a closer view of the inlay which was done in honduran rosewood, baked maple and balayoung.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:18 am
Here's a different view showing the fiber optic lights for the fret markers. I thought this was a bit showy but after playing on a dark stage they're really handy.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:22 am
I started using shielding paint instead of the copper shielding. Its application was easy and looks good and east to touch up if necessary.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:28 am
I also switched bridges to a KSM bridge the sound is a lot cleaner. After comparing this bass to an alembic the sounds of the two where almost identical tonally with my bass being a little more powerful (louder).
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:34 am
This picture shows the neck through construction. The neck woods are zebra wood, chechen, baked maple and strips of ebony veneer in between for a total of 9 layers. Also the center of the wings is mahogany.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:37 am
The fretboard is ebony lined with maple and chechen, this was my first time doing that. I really like the subtle effect it offers and proved to be fairly easy. I do have to change the point by the G string and round that off a bit as it catches your finger when slapping, whoops.
Paul Gransee
Postby Jim Bonnell » Thu Apr 19, 2012 11:41 am
Excellent work. I'm feeling inspired. Is that a brass nut and if so why do you prefer brass?
Jim Bonnell
Postby Paul Gransee » Thu Apr 19, 2012 11:47 am
Thanks Jim yes it is a brass nut I make them myself, it is adjustable (height wise) and I think it brightens the tone a bit. I also used a brass plate inlaid into the back for the string thru, I also think this helps in the sustain. When I play this bass the only effect I use is a volume pedal to cut it off at the end of a song. (it will ring a note forever)
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:49 am
A close look of the back side of the head stock which I covered with the same ebony veneer in the neck laminations.
Paul Gransee
Postby Paul Gransee » Thu Apr 19, 2012 11:54 am
I rotated the front view and hopefully a little better view of the whole front. I also want to thank Jim for letting me know that the picture problem was not me (as I assumed LOL). A couple of other things the pickups are EMG's, tuners are sperzal and I inlaid the strap locks for a cleaner look. In the future I hope to get a sound clip of this bass as this thing sounds better than it looks. The first time I played it my band mates where amazed that a different bass could be so unique in its sound. I also had to adjust the volume and gain to about half of what my other bass is played at.
Paul Gransee
Postby Dan Hehnke » Fri Apr 20, 2012 4:42 pm
Nice I love it! Myrtle is awesome stuff too. How does the raising and lowering of the nut work? I'm a fan of aluminum nuts on some of my (non-bass) guitars, wonder how brass would sound on those....could be fun to try.
Dan Hehnke
Postby david frassetto » Fri Apr 20, 2012 11:07 pm
Great job! I love the way the knots and the string retainer on the back look like a face<G>. The inlay on the neck is well executed and looks great. Nice touch.
Lap steel fanatic
david frassetto
Postby Paul Gransee » Sat Apr 21, 2012 11:29 pm
Dan i use 2 set screws from above to adjust the height. the center screw is adjusted from the under side.
top view.jpg (6.39 KiB) Viewed 12174 times
Paul Gransee
Next
