Bridge installation
marc lavertu
Bridge installation
Post by marc lavertu »
Hi!
I'm working on a new tele project. I have a hardtail bridge to install. The neck is at is place. I mark the center line and the outside lines too. I mesure the scale length and trace the line.
The only thing i'm not sure, Where do I place the saddle on the bridge to put it correctly on the line? I search but I can't find the answer.
Can you help me!
Thank's
Marc Lavertu
Re: Bridge installation
I place the high E string saddle (or E and D if it's a 2 string saddle) with the screw almost fully extended (toward the nut) on the line. That will give you the maximum compensation distance (toward the tail) for the low E saddle which will need the most compensation. You will never need to compensate any string from the line toward the nut, if you've measured the scale length correctly.
Post by Brian Evans »
I use a scale length calculator (this one: https://www.liutaiomottola.com/formulae ... sation.htm ) to determine exactly where I want each saddle for the scale length and string gauges I plan to use (unless I already know because I've done it before and wrote it down). I set the saddles in the bridge adjusted for the true compensation length, with the most extreme saddles (low and high E usually) in a not-extreme position on their screws, so I know I can achieve that compensation plus a little more each way, and use that to mark out the bridge location. You really only have to preset the high and low E saddles, but I tend to over-do things so I do them all. I make archtop bridge toppers the same way, fwiw, calculating offset from a median point.
Freeman Keller
Post by Freeman Keller »
If you run the StewMac fret calculator for your neck configuration it will give you a mounting measurement for any bridge they sell that can be used with that configuration
https://www.stewmac.com/SiteSearch/?sea ... calculator
The measurement is frequently to a convenient mounting hole. I use it but I double check using both the mottolo wizard and Peter's method - I know that I will never want to be closer to the nut from the scale length so if I start with that as being the shortest measurement I'm usually OK.
Peter Wilcox wrote:
Fri Mar 13, 2020 12:58 am
Oops! - that should be E and B.
marc lavertu
Thank Guys for your Help!!
