I need some advice right away! On me second template ( the first one was a big miss), I make just one little mistake, I got about 1mm, not more, inside the line. The error is in the red circle.
I can start a new one but you may have a solution. I think i will draw just the neck pocket, cut it and put it over with some 2 face tape! what will you do this case!
Thank you!!!!!
Marc
