Hi....
I'm sure someone will be able to help with this question.... I'm quite excited I've been asked to make a double neck, Bass and 12 string for a Genesis band that are touring in March, the guitar is loosely a copy of Mike Rutherfords "bolt rogether" Shergold which could be played as a two guitars or bolted together as a twin neck.. I'm fortunate in that the customer has supplied the necks otherwise the time frame would have been impossible, I'm well underway with the body templates finalised which is nice as I can mock the whole thing up and it seems to fit together well, I've got a local engineer machining the body joining mechanism and he's doing a fantastic job... The original Shergold method was a bit "clumsy" looking.
Anyhow my question is, I need to get both the 12 string and Bass bridges positioned and having only really worked on Fender 6 strings and not 12 strings and basses!.. I wanted to make sure I get them in the right place, is it just a case of doubling the distance to the 12 fret? or are there slight adjustments to this measurement for a 12 & Bass?
Many thanks....Chris
Bass and 12 string bridge position
Re: Bass and 12 string bridge position
That's close, but not quite exact. Research compensation, that will explain what you need to know.
By the way, compensation applies to 6 string fenders as well as 12s and basses.
Thanks Rodger...
I've looked "compensation" up and have got a better idea of where to fit the bridge....It's just that with Fender's I have templates with the bridge mounting screw holes already drilled so I've never really been too concerned.
Thanks Chris
Thanks Chris
