how to repair shallow ding
Robert Smallwood
Post by Robert Smallwood »
Hi.
I have had a lacquered ( Shellac cross linked ) body hanging for 3 months. When i took it down to start rubbing out I discovered a shallow ding about 10mm ( just under 1/2") across.
the top is highly figured wood stained with water soluble dye, and I very much want to avoid attacking the area with steam.
How would it look if I built up the depression with clear lacquer?
Is there a better way or is steaming the way to go?
Rob.
Re: how to repair shallow ding
Robert,
Is it a solid body instrument? I'd drop fill with whatever finish you've been using up to now. There's only one cross linking shellac I'm aware of, I think it's from Australia.
http://www.ubeaut.com.au/hardshell.htm
Robert Smallwood
That's the stuff, and that's what I'm going to try...i'm getting good at coping with powerless frustration... :o)
I feel your pain(t).
