I like using a Danish Oil finish because of the natural look and because it can be applied easily without a spraygun.
I've searched the internet for ways to apply Danish Oil on wood.
This search resulted in a wide variety of methods.
For a novice (like me), it's a bit overwelming.
What method should I try out?
Or are there just more ways that lead to Rome?
At this moment I'm trying two methods on pieces of scrap:
1. sanding the wood to 320 grid dry sandpaper and then apply one coat of danish oil, wipe het of after ten minutes and then the next layer I'll use 400 grid wet and dry sandpaper and wetsand the wood with some oil, wipe it of and repeat this step after a couple of hours with 500, 800, 1000 and 1200 grid.
2. (wet) sanding the wood until 1200 grid with water, let the piece dry and then apply a couple of coats of oil.
I'm curious about the method that others use.
Which steps do you take to get to a good finish?
Do you use different methods on different kind of woods?
Do you / can you buff the finish?
Do you apply an extra coat of shellac of epoxy on it?
Do you have a picture of the end result?
Hans
Applying Danish Oil: What's your method?
- Hans Bezemer
- G.S. Monroe
Re: Applying Danish Oil: What's your method?
I love Danish oil... it and hand rubbed shellac are my two preferred finishes.
1st) Wood prep... Sand with 120, 220, then 320 grit.
2nd) Burnish raw wood with fine steel wool.
3rd) Apply a quality Wood Conditioner (Minwax) to help avoid blotchy absorption issues.
4th) Apply Danish Oil with a clean cotton (lint free) rag. Wet rag with the Danish oil and wipe with the grain.
Let rest for a hour between coats. Apply 2-3 coats. Then wet sand with 400 grit and Danish Oil,
making a slurry that will fill pores and scratches. Wipe down with soft cotton cloth, wiping with the grain. Let dry Overnight.
6th) Apply 2-3 coats of Furniture wax, (I prefer Old English), and buff to a satin finish.
- Hans Bezemer
Thanks Greg.
I've finished the to scap pieces and both some wax on both of them and they look nice.
This reply intrigues me. My two upcoming finishing projects are a Cherry Tele and then a Pine-Beetle U-Bass. For the Cherry, would applying the wood conditioner help prevent/limit the blotchy finishes that can happen with oil-based finishes and Cherry? For the Pine, I assume I'll need some additional grain/pore filler. Do you have any recommendations for that, and would the finish let the blue 'beetle streaks' show through?G.S. Monroe wrote:I love Danish oil... it and hand rubbed shellac are my two preferred finishes.
- G.S. Monroe
Sam, I definitely would recommend using a wood conditioner on any kind of wood prior to applying a stain or oil based finish. It serves two purposes, 1) It is made from penetrating oils that not only inhibit uneven or blotchy absorption, but helps to promote a deeper absorption into the wood. 2) It helps to seal the wood so it takes less oil to achieve results. I like wood conditioner so much that I apply it inside the acoustic chamber as well as on the outside of the instrument. Basically everywhere there is exposed wood get at least a coat of wood conditioner.Samuel Hartpence wrote: This reply intrigues me. My two upcoming finishing projects are a Cherry Tele and then a Pine-Beetle U-Bass. For the Cherry, would applying the wood conditioner help prevent/limit the blotchy finishes that can happen with oil-based finishes and Cherry? For the Pine, I assume I'll need some additional grain/pore filler. Do you have any recommendations for that, and would the finish let the blue 'beetle streaks' show through?
For pine or any "open pore" wood, I typically apply a sealer coat, and wet sand with 400 grit and your oil or shellac to fill pores. The beetle streaks will show through unless you do something to remove, cover, or mask them before hand.
What does a "wood conditioner" actually do? What is in it? Never heard of it before.
Thanks.
Thanks.
