sanding with 500 fre cut
Bryan Jeppson
Post by Bryan Jeppson »
The 500 grit, though harder to come by, sure saves time versus 600 for finishes, but doesn't leave scratches like 400. Granted I'm using KtmSv instead of nitro, so taking down a harder finish will really make one appreciate the difference.
John Hall
Re: sanding with 500 fre cut
Post by John Hall »
I used to do a lot of finishing but farm most out. I found that a good selection of grits will make the task more efficient. I would gauge things but the amount that I cut through the "orange" peel. I used a 400 wet to get 1/3 the way through the rough surface then jump to 600 and used 800 to hit the bottom. Depending on the point of finish cycle I am on. Once I am leveled I went to 1000 and worked up to 2500 grit and then the buffer
John Hall
Nelson Palen
Post by Nelson Palen »
Are you guys talking P grade or CAMI grade?
