Veneer Saw.
Gilbert Fredrickson
Veneer Saw.
Post by Gilbert Fredrickson »
I've been using a razor knife to cut veneer strips for purfling. It works okay when I carefully make multiple passes. Is a veneer saw a better tool to use for this. The veneers are usually stacks of 0.010 and 0.020 dyed maple. Thanks.
Re: Veneer Saw.
In the past I always used a utility knife with multiple passes. The issue is that the knife will sometimes stray away from the straightedge and follow the grain. A veneer saw will not do that since it cuts through the grain instead of following it. It definitely works better.
Gilbert Fredrickson
Re: Veneer Saw.
Thanks, Barry. I'll let you know how it works out.
Re: Veneer Saw.
You may still need a few passes but like Barry said it won't follow the grain like a knife.
Re: Veneer Saw.
Make sure you have a soft board underneath so you don't dull your saw when you cut through the veneer.
Re: Veneer Saw.
Gilbert Fredrickson wrote: Wed Jan 27, 2021 10:19 pm I've been using a razor knife to cut veneer strips for purfling. It works okay when I carefully make multiple passes. Is a veneer saw a better tool to use for this. The veneers are usually stacks of 0.010 and 0.020 dyed maple. Thanks.
If you are stacking veneers you might want to use a half moon blade mounted on an oscillating tool.
Gilbert Fredrickson
Re: Veneer Saw.
Yes. I use a really low angle when I pull the blade across the veneer. A curved blade would definitely improve the cut edges of the purfling strips. Thanks.
Return to “Tools and Jigs”
