LMI wood
wood choice for sound board on Weissenborn style.
Postby Bob Howell » Tue Jul 19, 2016 9:23 am
Making this as my first guitar.
Ribs will be Sapele and back can be sapele, figured maple or walnut, mix with rosewood strip. Several options.
I have resawed flat sawed maple and walnut. I have quarter sawed walnut and sapele and stika spruce.
The top can be mix of walnut and sapele or stika spruce.
Over the years I have seen discussions about relative stiffness of back and top. Don't see them now. Started this project in 2011 by cutting the wood then put it on hold as life got hectic.
What are thoughts out there?
Bob
Bob Howell
Re: wood choice for sound board on Weissenborn style.
Postby Brian Evans » Tue Jul 19, 2016 12:32 pm
Weissenborn guitars traditionally had hardwood tops, I think mostly koa and mahogany. I think of koa and mahogany as being very similar and suitable as top woods, and the same with sapele. I am not as sure about walnut as a top wood. Sitka spruce is always an excellent choice for top wood. If I were to rate your choices, it would be the spruce, then the sapele and walnut or a mix of walnut/sapele last.
Postby Bob Howell » Fri Jul 22, 2016 3:16 pm
Back in 2010-12 I followed a number of threads about wood used for Weissenborn tops. I can't find them now but several were experimenting with sapele and spruce. Even domestic hardwoods. I am wondering how they came out.
Bob Howell
Postby Todd Stock » Wed Jul 27, 2016 6:55 am
I've built khaya (aka, african mahogany) Weiss's and they look/sound great. If you can resaw, khaya is fairly cheap, available in vertical grain, wide boards, and works about as well as South American mahogany. High Mountain Tonewoods was processing spruce soundboards for Weissenborn instruments a few years ago - could always ask them about a set if you want to go with softwood top.
Todd Stock
Postby Bob Howell » Sat Aug 06, 2016 4:15 am
I Have sapele and I may have walnut if my efforts to re saw several slabs pan out. I did not think of khaya and bought more sapele to re saw.
I lean toward a hard wood top.
Bob Howell
