Question about matching top wood
- Eric Knapp
Hello,
Here's a question that's been bugging me for a long time. I have a long Sitka spruce board that's 10 inches wide and almost 1 inch thick. It could be resawn for an acoustic top but I want to use it for an archtop. I would not be able to bookmatch the wood so is it still possible to use? This would be for an early build, not a master instrument. What would be the best approach to using this wood for an archtop if possible?
Re: Question about matching top wood
I had a nice, quartersawn piece like that that became a mandolin top. The grain was so uniform that turning a piece around and jointing and gluing it did not betray that it wasn't bookmatched. The wood was just too nice not to use that way.
- Eric Knapp
Thanks, how did you turn it around? I can see 2 or 3 ways. Did you flip it over or rotate it? Or did you just move the next piece down and join it so the grain was in the same direction? This board is perfectly quartersawn too, with very even grain. It's been sitting in my shop for a long time waiting for me to get my act together and use it.Bob Gramann wrote:I had a nice, quartersawn piece like that that became a mandolin top. The grain was so uniform that turning a piece around and jointing and gluing it did not betray that it wasn't bookmatched. The wood was just too nice not to use that way.
I don't remember how I turned it. I just made sure it looked good.
I do this, being too cheap to buy "official" book-matched archtop sets. Pay a lot of attention to grain direction with an archtop, it really sucks to be fighting tear-out all along the center seam. I use 1" thick rough sawn stock.
- Eric Knapp
Thanks, It sounds like the procedure is to first cut some pieces to length. Then try hand planing along where the top joint might be. Find a compromise between looks and grain tear-out. Sounds doable. I'm looking forward to trying.Brian Evans wrote:I do this, being too cheap to buy "official" book-matched archtop sets. Pay a lot of attention to grain direction with an archtop, it really sucks to be fighting tear-out all along the center seam. I use 1" thick rough sawn stock.
If the non book match is a bit too obvious you could consider doing a sunburst finish slightly darker than the average sunburst.
- Eric Knapp
Thanks, doing a sunburst is another thing I need to learn anyway. I don't have a spraying rig yet so I'll have to figure that out when the time comes. A lot to learn!Joel Nowland wrote:If the non book match is a bit too obvious you could consider doing a sunburst finish slightly darker than the average sunburst.
Ignorant newbie question.
Why can't you bookmatch it? My guess is you want more than a 1/2 inch arch.
Excuse me please...
Excuse me please...
- Eric Knapp
Yes, from what I'm seeing in the literature and online, an archtop blank starts out at 1 inch or more. I have not encountered a 1/2 inch archtop. I think that would be too shallow. I've not made an archtop so I could be wrong though.Thomas Yerkey wrote:Ignorant newbie question.
Excuse me please...
You're not wrong. In order to get a one inch rise in an arched plate, you actually need to start with at least 1-1/4" thick stock.
- Eric Knapp
Thanks for the verification. I hope a full 1" board will be good enough for a first build.Barry Daniels wrote:You're not wrong. In order to get a one inch rise in an arched plate, you actually need to start with at least 1-1/4" thick stock.
There's a lot of spruce out there but sometimes having an immovable limitation gets you to a higher plane in a project like this.
- Jim McConkey
Also, plates for arched instruments are usually not cut flat. A 1" piece thick slab would be split diagonally so that one side is 3/4" and the other side and the other is 1/4". You cannot simply open a set cut like this like a book. You have to turn one piece around 180 degrees so that fat sides can be joined. You have to leave at least 1/4" on one edge, which is why Barry says you need a 1 1/4" board to get a 1" arch.
My plates start with 4/4 rough stock, which is 1" plus a hair thick. Benedetto starts with 1" thick stock as well. In his book, he uses boards, not wedges. FWIW.
Brian
Brian
- Eric Knapp
That's great to know, thanks. I don't have the Benedetto book yet and it sounds like I need to get it soon.Brian Evans wrote:My plates start with 4/4 rough stock, which is 1" plus a hair thick. Benedetto starts with 1" thick stock as well. In his book, he uses boards, not wedges. FWIW.
Brian
Very true and I think I've said that to my students on more than one occasion. It was in a completely different context but the principle still holds up.David King wrote:There's a lot of spruce out there but sometimes having an immovable limitation gets you to a higher plane in a project like this.
It's also good to hear there is a lot of spruce out there. One of the local lumberyards here specializes in supplying boat and iceboat builders. They have a large supply of very long Sitka boards. Some are 20 feet and more. The last time I looked they had a bunch that were 4/4 rough sawn and at least 10" wide. The grain looked great, too.
Archtops/violins/celli and the like are where splitting logs really works better than sawing. The very nature of splitting ensures that you get appropriate wedges. I see quite a lot of wedges for sale on the German ebay. One particular seller. I probably won't buy from that source but the stuff is available at fairly ok prices. Given how much work and arch top is, I would get wedges.
- Eric Knapp
That sounds right for a serious build. The board I have will probably work well for my first few archtops, should I get that far. (I'm hopeful, as are many, I know.)Simon Magennis wrote:Archtops/violins/celli and the like are where splitting logs really works better than sawing. The very nature of splitting ensures that you get appropriate wedges. I see quite a lot of wedges for sale on the German ebay. One particular seller. I probably won't buy from that source but the stuff is available at fairly ok prices. Given how much work and arch top is, I would get wedges.
