LMI wood
Bending Jotaba
Bending Jotaba
Postby Robert Freemond » Sat Sep 15, 2012 11:30 am
I've recently bent some Jotaba for sides & the results were not so good. The wood cupped in several places over the length & seems to be related to the curliness of the grain in the spot where it warped. Anyone have any experience with Jotaba ? By the way, I'm using a Fox bender with stainless shim stock(.012) + a heat blanket. I start my bend at 250*.
Robert Freemond
Re: Bending Jotaba
Postby Nicholas Blanton » Sat Sep 15, 2012 12:11 pm
I suspect there's a lot of difference in shrinkage between flat-sawn and quarter-sawn jatoba, that makes anything not one or the other move a lot. And there's hard-to-see reaction wood as well- which could be the curliness you noticed. Run-of-the-mill jatoba boards often bend and warp when ripped down to size, and generally show a mind of their own, even after long dry storage. It's also possible that, since the stuff is often sold as flooring, it is badly kiln-dried as well. It's cheap enough, I'd throw out the sides you've bent and try some more with the most boring figure and the most vertical grain you can find.
Nicholas Blanton
Re: Bending Jotaba
Postby Mark Swanson » Sat Sep 15, 2012 12:44 pm
How wet did you get it when you bent it? Use hardly any water at all, even dry works just fine. Too much water- even just a little too much- will cause that cupping.
Re: Bending Jotaba
Postby Robert Freemond » Tue Sep 18, 2012 3:19 am
Mark, You may be right. It's been hot here in LA so I spritzed both sides & wrapped the sides in foil. I've seen Taylor's Videos & he uses no water at all. I'll try your suggestion & also what Nicholas said about straight grain. I might also look for some stiffer shim stock for my bender.
Robert Freemond
Users browsing this forum: Google [Bot] and 2 guests
