Piezo / Preamp Noise Problem
Mark Wybierala
Post by Mark Wybierala »
Every once in a while I'll get in an acoustic guitar that has what presents itself as a ground hum problem. These could be any typical manufactured acoustic with an undersaddle piezo and active preamp. The symptoms are excessive noise at higher signal levels and noise interrupt when you touch the metal backshell of the instrument cable and, the pickup is still actually functioning with a strong output (its understood that the cable and the amplifier has been ruled out). Sometimes its just a dirty/defective or miswired output jack and that is my first thought. But I have had instances where the cause has been a defective undersaddle piezo pickup. The fact that there is what seems to be ground problem and the noise is impacted by touching a finger to the backshell of the instrument cable causes me to not be so confident.
For clarification,... There are a number of piezo formats ranging from the simple piezo cable which is just a thin coaxial wire with the insulator made of piezo material to a number of other sandwich styles. The ones that I've had problems with are the very plain rigid strip that looks like it has a thin covering of foil and a typical example is the Martin Thinline. The current replacement from Fishman is called the AG Series.
I have personally accidentally damaged a piezo while rushing during a saddle height adjustment resulting in this noise problem and have successfully addressed this problem on at least two other occasions by replacing the piezo. Over the years I've purchased quite a few piezo pickups on ebay at dirt cheap prices in lots with a single unit cost of about $2 and have accumulated a wide range of sizes and thicknesses. The $2 piezos work great but it is rare to find them on ebay in the narrow width format (3/32 / 2.3mm) leading to the necessity of paying around $100 for a narrow format pickup from Fishman. Hey, if the client has a defective pickup and the cost is $100, that's okay but I don't want to spend 100 dollars of the client's money on a guess. Talking to Fishman support, they concur that the problem is likely a defective pickup but I feel so much more confident when I troubleshoot a problem and discover the cause and prove it through an actual measurement or visual confirmation. Swaptronics is a proven technique but I don't like it when its expensive.
The first thing is that I don't understand the theory or reason a piezo element would do this. My guess is a hairline fracture of the foil-like outer conductor. This foil is delicate and easily torn by sharp objects. I understand that this foil is the equivalent of the ground side of a magnetic pickup.
Can I replace the pickup with a 1 Meg resistor at the preamp and if the noise problem at high gain goes away be confident that the problem is actually the piezo? Any more thoughts on this are appreciated.
Re: Piezo / Preamp Noise Problem
Maybe I'm not understanding correctly, but could you just replace the pickup with another (presumably good one) at the preamp (size wouldn't matter since it's not in the guitar), and see if the noise is gone?
Post by Bob Gramann »
As I was reading, I thought “why not replace the pickup with a resister and see if the noise disappears?” Then, I got to your question in the original post. So, yes, I would consider that a good strategy as is Peter’s. If it doesn’t work, we all need to know because it just seems like the right thing to do. Replacing at the preamp doesn’t rule out a cause in the lead wire. I would also consider that the pickup could be wired backwards to the preamp, the foil side to the input rather than the ground. Or, there could be a cold solder joint at the ground connection. I bought a Fender electric bass some time ago that had a horrible hum. When I opened it, I found that the wiring to the pickups was not shielded cable, which I didn’t expect, but rather two single wires each. The wires to the pickups had not been twisted between the control panel and the pickups. I put a few turns on the wires and the hum disappeared.
Mark Wybierala
I was in this guitar a few weeks ago. Its a budget Martin with a Fishman preamp (OEM) setup. I replaced the output jack with no change. The pickup plugs into the preamp with a tiny jack and I found a small amount of corrosion on the jack. I removed the jack from the preamp circuit board and soldered the shielded wire from the pickup directly on to the circuit board. It seemed okay so I assumed the corrosion/compromised jack was the problem. The guitar is back again with the same noise issue. I actually did a thorough check and double check of the correct wiring of the output jack -- its the standard three conductor setup with battery/ground establishing a path via the stereo plug. I'm certain the pickup is wired properly too. I'm going to establish a few more observations before I proceed.
If you suspect a grounding issue why not check continuity from the foil wrap of the pickup to the output jack sleeve/threaded barrel?
$100 seems like a lot to pay for a Fishman replacement. You might set yourself up as a Martin repair center and get the replacements from Martin at something closer to their cost. EMG makes a fine drop-in system that's also very reasonable as a dealer/luthier (though it might be easier to set something up with the local EMG dealer for the occasional need.)
I hate under-saddle systems so much I'd select something easy to manage, battery-free, cheaper and better sounding like K&K or equivalent and just replace every problematic one with a surface-mount transducer type.
Mark Wybierala
I spoke directly to Martin customer service about this instrument and they do not provide tech support for the electronics of these guitars unlike Taylor who have always offered outstanding support. I hoping that this was just a single Martin employee having a bad day because I would like to think highly of Martin. The preamp has the Fishman name on it and although the preamp is not a model of their current products catalog, generally Fishman will always spend the time on the phone talking with you and trying to help.
Mark Wybierala
I carefully searched through the text of ebay listings and found three listings that specified the 2.3mm thin format piezo and ordered a quantity of them cheap. Not a lot of investment if they turn out to be wrong. $99 is way too much for a piezo.
Let us know how those inexpensive ones sound if you can hear any difference in signal level and tone.
Post by Chuck Tweedy »
Yes - please do continue the conversation. I actually have a very similar situation, but thankfully it is not a customer's instrument I'm working with.
Mark Wybierala
I ordered 3 ea. from three different ebay vendors in China. About $1.99 per unit average. Although each of these vendors were different in name and reviews, they all used the same pictures on their ebay listing. All three packages arrived about three weeks earlier than the estimated date of delivery in minimally protected packaging (a padded bag/envelope) but there was no damage. They are indeed the correct width and look very similar to the OEM pickup -- exact color (metallic Ruby Red), exact width, same length, same lead wire, but they are all slightly thicker in height by about 50% -- not really an issue -- about .030" and in my situation, the .030 resulting increase in saddle height was advantageous to the setup of this guitar. The noise problem is cured. I called the client two weeks after I finished the job and he is totally pleased with the performance and tonal response of the guitar.
Had the dimensions of the pickup been exact, I might be tempted to believe that I was getting the exact same $99 part sold by Fishman from the factory that supplies Fishman but this is not the case. They are an intentional copy/clone. But they work and seem to work well. It did address the noise problem.
I'm willing to bet that Fishman still makes their own transducers as that's their main business and always has been. There are many variables to contend with regarding the material, it's formulation and how it's oriented.
Rob Kidd
Post by Rob Kidd »
Piezo pickups have huge impedance, and their signal and the high impedance input at the preamp needs very good shielding.
I would check the continuity of the copper shielding and the braid. I would also consider cutting the pickup's lead so that it's no longer than it has to be. Also consider replacing the lead itself. Some I've seen have a very loose and open weave for braiding. The lead should have tight and full coverage from the braided shield.
