If you a looking for a low impedance pickup that is magnetic but small, might I suggest you look at variable reluctance gear teeth sensors. The downside is the price and size in that one must place them close to the bridge such that the string excursion stays within the sensing range. The plus side is the clean signal output. I used these back in '82 on my first bass. As a consequence of the position, the output is harmonic rich compared tot he fundamental but that can be coloured should one require. I mixed in an amount of fingerboard pickup from a humbucker and then color the signal.
An alternative if one requires a pickup closer to the fingerboard would be to make an individual pickup per string that is not a humbucker plus one background pickup and subtract that signal from each individual signal using op-amps. You could also pair neighbours where you have an even number of strings.
That said I can think of a few ways to put together a small single turn humbucking pickup with current transformer but not easy to make.
Low Impedance pickup - prototype
Jump to
- Forum Rules
- Frequently Asked Questions
- The Soundhole
- ↳ Introduce yourself here!
- MIMF 25th Anniversary
- ↳ Auctions
- ↳ Giveaways
- Support the MIMF
- Challenges
- ↳ The Local Materials Challenge (Closed)
- ↳ The "Reclaimed Materials" Challenge (closed)
- ↳ The "Try Something New" Challenge (Closed)
- Flat-Top Acoustic Guitars and Bass Guitars
- Solid-Body and Chambered or Semi-Solid Electric Guitars and Bass Guitars
- Archtop Guitars and Bass Guitars
- Bowed Stringed Instruments and Bows
- Ukuleles
- Other Stringed Instruments
- String Instrument Repair: Practical and Political Issues
- Wind, Percussion, and Miscellaneous and Experimental Instruments
- Electronics
- Wood and Materials Q&A
- Tools and Jigs
- Glues and Finishes
- CAD/CAM/CNC - hardware and software and its uses in luthiery
- Classified Ads
- Builders' Supplies and Services
- Jam Session
- ↳ Builder's Groups
- Detailed Builds/Tutorials
- Product & Component Reviews (test)
- ↳ Tools
- ↳ Trussrods
- ↳ Electronics
- MIMF Projects
- ↳ MIMF Bass 2001
- ↳ MIMF Bass 2012
- ↳ MIMF Archtop
- ↳ Hurricane Katrina Volunteer Work
- ↳ Nashville Volunteer Work
- MIMF 20th Birthday!
- ↳ The party!
- ↳ Chocolate!
- ↳ Auctions
- ↳ Mini-auction #1 (closed, closes 9 PM server time March 25th)
- ↳ Final auction, ends July 5th (closed)
- ↳ Mini-auction #2 (closed 9 PM server time April 23rd)
- ↳ Mini-auction #3 (closed 9 PM server time June 4th)
- ↳ Birthday Contest
- ↳ Give-aways
