Stringless, Friction and Tap, New Instrument, Inspired by Vai, Jaco, Silent Zildjian Cymbals,
Postby mustafa umut sarac » Sun Apr 02, 2017 8:41 pm
Cut flat rectangular wood, plastic or metal plate ,Tune it to an note by shortening, attach a piezo to bottom corner And than plug to amp.
When you tap, friction to the surface of plate closer to the piezo , notes are thinner, When you tap, friction to the surface of plate far from the piezo , notes are thicker.
No strings, no tension, no luthier, near to free
Here is the instrument.
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOPIEZO_____________________________AMP
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Mustafa Umut Sarac
Istanbul
mustafa umut sarac
