Sta-Tites won't stay tight
Postby Thomas Wentzel » Mon Apr 02, 2018 3:03 pm
Greetings, I have a guitar with the 30s Grover 'Sta-Tite tuners with metal buttons. The button spins on the shaft. Normally, on a plastic button, I'd likely flatten the 'wing' of the shaft a bit and re-insert, or just put on a new button.
Has anyone had success repairing the original metal button? ..solder?
Appreciate any help..thx..Tom
[img][IMG]http://i271.photobucket.com/albums/jj126/onewent/IMG_8941_zpstpn8eot7.jpg[/img]/img]
Thomas Wentzel
Re: Sta-Tites won't stay tight
Postby Daryl Kosinski » Mon Apr 02, 2018 10:47 pm
If it were mine I would remove the tuner from the guitar and take it apart as far as possible clean both parts then solder it back together.
Re assemble the tuner lube it with a few drops of clock oil and you should be good to go.
Daryl Kosinski
Postby Thomas Wentzel » Tue Apr 03, 2018 1:43 pm
Thanks, Daryl .. I actually was messing around with it yesterday, and I simply put the shaft on a vise, and whacked it with a hammer a few times to flatten the tab a bit. Then I pressed the button back on in my vise. Seems tight, and works well.
If it loosens I'll likely go the solder route.
Tom
Thomas Wentzel
