Repairing worn wood around soundhole
Postby Keith Howell » Wed Jan 18, 2017 4:05 pm
Any thoughts or recommendations on repairing this damage around a sound hole on a Taylor guitar?
The owners playing style has worn the wood out from between the inlay.
My idea is to route out the damage and replace the wood tinting it to match then cover the area with an auxiliary clear pick guard.
Keith Howell
Re: Repairing worn wood around soundhole
Postby Barry Daniels » Wed Jan 18, 2017 8:29 pm
I wouldn't do it. The repair will be difficult, time-consuming, and will never look like new unless you have mad skills.
Postby Greg Steil » Thu Jan 19, 2017 9:33 am
that just seems to be a can of worms that should stay sealed. Protect the bare wood with some shellac perhaps..
Greg Steil
Postby Steven Smith » Thu Jan 19, 2017 12:10 pm
I would try to clean the bare wood between the rosette rings with deionized water. Once it looks ok, and it's dry, coat the wood with CA to provide some protection. It's not going to look new again but you might be able to keep it from getting worse.
Steven Smith
Postby David King » Thu Jan 19, 2017 2:07 pm
Clean the wood as best you can with an eraser and a mild bleach solution. At that point you could put a colored shellac to restore the color and finally drop fill with a clear polyester resin finish or CA. Ideally the shellac would make any drop fill reversible. Certainly the CA would be reversible but the polyester would hold up a lot longer. This is a factory made guitar, might as well make it last. After the drop filling I'd probably add a mylar pick guard strip that could easily be replaced as it wore out.
Postby Brian Evans » Thu Jan 19, 2017 3:03 pm
I was about to write exactly what David King wrote, so I won't... :) Gel CA glue would be trapped and held in place to some degree by the raised purfling strips.
Postby Bryan Bear » Thu Jan 19, 2017 3:45 pm
What they said ^^^
If you go the CA rout, definitely seal with shellac first. CA can wick into spruce endgrain and stain it yellow; the shellac will prevent this.
Postby Keith Howell » Sun Jan 22, 2017 4:33 am
Thanks all.
The consensus is: Clean, seal with shellac and fill with CA and cover with an auxilary pickguard.
Now to get he guitar into my work shop. It is a hardworking pro's instrument which has very little downtime.
Keith Howell
Postby David King » Sun Jan 22, 2017 5:11 pm
Drop-filling with CA is a bit of challenge for me anyway. The medium or thick viscosities seem to work better but patience is the key. My best results come when I lay down a thin layer over the area at the end of the day and leaving it to set up on it's own over night. Multiple coats will have time to shrink down this way.
If you're in a hurry get the accelerator spray that won't cloud the finish, mask off the area carefully, spray a light coat, let it flash-off completely (10-20 minutes) then apply your medium CA from a pipette (you can toss it out if the tip gets contaminated from the accelerator). This assures that the CA cures from the bottom up and won't develop internal crazing or bubbles.
Since it's summertime in SA you might try a bottle of Solarez from a local surf shop. That should be quick, tough and won't shrink back. It's essentially what's on the guitar now.
Postby Bob Gramann » Sun Jan 22, 2017 5:19 pm
When a customer asks me for a cosmetic repair, I often think "You can always make it worse." Many times, a cosmetic repair doesn't quite end as nicely as you would like and just draws attention to the problem. There's really no harm in a working instrument looking like a working instrument. If you use it, sooner or later, it's going to show. That's okay.
Postby Keith Howell » Mon Jan 23, 2017 11:44 am
This is not really a cosmetic repair. Nick, the owner plays, amongst other styles, a very percussive style we call "Boland Bop" and it is wearing the sound board out around the hole quite aggressively. The edge is about to wear through and then the hole size will begin to change with, I reckon, all sorts of effects on the sound.
So it is a case shore it up now before the edge crumbles completely and it starts looking like Willie Nelsons guitar.
Keith Howell
Postby Bob Gramann » Mon Jan 23, 2017 12:15 pm
Can you simply replace the pickguard with a larger one covering all of the affected area?
Postby Clay Schaeffer » Sat Jan 28, 2017 11:18 pm
You could carefully color match the spruce with pigment powders and then fill the gouged out areas with clear epoxy. The epoxy will build quicker than CA and be less likely to turn white. Or as others have suggested build up the area slowly with CA.
