Dental tools
Dental tools
Postby Charlie Schultz » Sun May 07, 2017 3:05 pm
Donated by Matthew Lau (thanks Matt!).
Matt says:
It is a curing light, a charging plug, bonding agent, some soon to expire b2 composite, and hardened steel picks.
The curing light is cordless. It is used to harden the composite filling material, after using bonding.
My recommendation:
1. Clean off the saddle/nut. Dry thoroughly
2. Paint a thin layer of bonding agent to site that you'll add to. Light cure.
3. Add composite material to as desired to final shape. I recommend no thicker than 1 mm increments. Light cure.
This stuff will be harder than steel when cured.
In terms of the curing light:
1. if light is out of batteries--remove battery from light.
2. Place battery in base. Plug into wall.
3. Pull out battery when charged. Put into light. Press button.
The adhesive is marked "expired" (3/17) and the composite has a marked expiration of 7/17.
He also notes that the composite can only be bought by a dentist, so buyer beware.
This is a little out of the ordinary, and is worth quite a bit new. Let's start the bidding $30 and USA shipping is included.
Re: Dental tools
Postby Steven Smith » Mon May 15, 2017 10:11 am
I'm in for $30.
Steven Smith
Re: Dental tools
Postby Charlie Schultz » Mon Jun 05, 2017 8:01 am
Congratulations Steve, please PM me your mailing address.
Re: Dental tools
Postby Steven Smith » Sat Jun 10, 2017 2:23 pm
Package arrived today in perfect shape. Thanks Charlie and Matt! Now I just need to learn to use it but I have a great relationship with my dentist so I'm sure he'll help if I have questions. The extra tools will come in handy too.
Steven Smith
Return to Mini-auction #3 (closed 9 PM server time June 4th)
