Chris Larkin's archtop neck joint
Postby Beate Ritzert » Tue Sep 19, 2017 6:45 am
In the net i found a build log of an archtop bass made by Chris Larkin (btw. a very impressive instrument, i had the chance to play it). To me the most interesting part of the build log is the neck joint - easy to make and with comparatively low demands on the precision. But the result is nearly inherently perfect.
Here a link to the relevant part of the documentation
To my understanding, that technique can also be used in connection with a violin type neck joint.
Beate Ritzert
Re: Chris Larkin's archtop neck joint
Postby Barry Daniels » Tue Sep 19, 2017 12:39 pm
That is the neck joint first shown by Irving Sloane in his book "How to Build a Steel String Guitar" first published in 1975. This is the book that got me started. However, this is not exactly the modern or traditional approach. And not a joint that provides any ability for adjustment, and like you said "no precision". I would not recommend this joint. There are much better options.
