Hello everybody
New to the forum? Feel free to introduce yourself here.
Hello everybody
Postby Anthony Bradshaw » Fri Oct 12, 2018 2:44 am
Hi folks,
This is my first post as I am a newby. I am currently (attempting) to build my first
guitar which is based on the G J200 jumbo. I never new that making an instrument can
be so rewarding. I am new to woodworking but have joined a wood shed and they have
all the tools required to make a guitar. Never having posted before I'm not 100 % sure
I am doing this right but I have a problem. I have braced the back of the soundboard and
have realized that the bracing is not long enough to fit into the notched sides when I
close the box. Is there an easy solution? I would really appreciate any help. Cheers
Anthony Bradshaw
Re: Hello everybody
Postby Bryan Bear » Fri Oct 12, 2018 9:22 am
Welcome Anthony! I too was new to woodworking when I started; it is good that you have some woodworkers around to helo you get started. Read all you can in the library here too and also ask questions.
As for your braces, Post a new question (preferably with a picture) in the instrument repair section, it will get more traffic. Without seeing it, my first thought would be to plane them off and put new ones on.
Re: Hello everybody
Postby Anthony Bradshaw » Fri Oct 12, 2018 10:07 pm
Thank you Bryan
your response is appreciated.
Anthony Bradshaw
Re: Hello everybody
Postby Gordon Bellerose » Wed Oct 17, 2018 11:02 pm
Anthony. Welcome to the forum!
I do not have an answer for your short brace issue, but I would like to welcome you.
Re: Hello everybody
Postby Jim McConkey » Fri Oct 19, 2018 2:26 pm
Welcome to the Forum, Anthony!
You can chisel out the kerf above where the brace should have fit in, and replace it with a larger triangle that sticks out far enough to secure the brace.
Jim McConkey
Return to Introduce yourself here!
