truss rod question
truss rod question
Postby Chris Flynn » Sun Apr 15, 2012 10:42 am
I am getting ready to build a Bass for myself and one for my friend at the same time, I have built 12 or so guitars, in acoustic, electrics, and a couple of basses, I have always used the old fashioned gibson truss rods, made from the steel rod and have had good luck. but this time is am going to try a neck through. I thought I remember reading in Melvin H's book that he is not a fan of two way adjustable rods. I do know his book was written before the availablity of the the ones that are available today. so do they work better than the old fashion gibson style,
what does everyone think about truss rods. today. I tried a search on this and there does not seem to be much discussion on it in the new forum maybe there was in the old one. or maybe I am just not asking Mr. search button the correct questions. HA.
thanks in advance for your reply's
Chris Flynn
Re: truss rod question
Postby Bob Gramann » Sun Apr 15, 2012 10:49 am
I vote for the two-way rod sold by Allied Lutherie. It works very well. Coat the threads with an anti-seize compound before you install it. You will like it.
Postby David King » Sun Apr 15, 2012 12:43 pm
I'm still not a fan of the two-way rods. I'm really liking the tone, weight and effectiveness of a single curved rod. They aren't the easiest the install and getting the curve and depth just right is not for the faint of heart but I don't think there's a better way.
Postby Greg Robinson » Mon Apr 16, 2012 3:11 am
Another vote for the Allied Lutherie two-way rod. I've said it before, and I'll say it again. Hands down the best rod on the market.
Greg Robinson
Postby julian gifford » Mon Apr 16, 2012 12:26 pm
I still havent tried the rods from allied but like above, everyone says they're the best. I always use 2 way rods though.
As for an anti sieze compound on the threads, use vaseline (petroleum jelly) it will always stay in place and never dry out (unless you leave the guitar in a car in summer maybe it will ooze some) Thats what fender uses on their threads.
julian gifford
Postby Rodger Knox » Mon Apr 16, 2012 12:43 pm
+1 for the Allied rod. I've also used the StewMac rod, which is also very good, but with major differences.
The Allied rod only requires a 3/8" deep slot, the StewMac requires 7/16".
The Allied rod is 1/4" wide, the StewMac is a little less, it's not tight in a 1/4" wide channel. I believe StewMac sells a router bit.
The StewMac rod is more "sensitive" 1/4 turn gives about the same adjustment as 2 turns on the Allied rod.
Rodger Knox
Postby Chris Flynn » Mon Apr 30, 2012 12:31 pm
thanks for the input. after thinking and reading these post, I am going to build one with an allied rod, and the other with the old fashion Gibson rod, since I am building one for me and one for my friend, it will be interesting to see and hear the differences, I am going to use identical wood, pickups. bridges, tuners, and finish, should be interesting. It will take a while for me as work building cabinets, and furniture has really picked up, ( been a long 6 years since the housing crash.. HA)
Chris Flynn
Postby Greg Martin » Mon Jul 02, 2012 8:33 pm
I made my first guitar was from melvins book and I too adopted the single action truss rod as well. Used with graphite rods I thought nothing could ever beat that combo. But now we have 2 manufactures allied and WD who really do make great 2 way rods especially for bass where I believe it is necessary. I build a lp clone in 2010 and used a wd 18" 2 way rod along with the graphite rods which I still install in every build,and love it.the neck is so stable and the relief in the neck is exactly where it needs to be .Technology some time is a great thing.
Greg Martin
Postby Mark Swanson » Mon Jul 02, 2012 9:40 pm
Yes, and sometimes it isn't...such as here, where we require the use of full names first and last. If you'll tell one of the moderators you last name we'll fix that for you, thanks.
