A Quick Question About Guitar Wiring
Postby Kelly Marshall » Thu Feb 08, 2018 10:38 pm
recently bought some new pickups for my guitar and I decided to rewire the whole thing while I was at it. Which is probably dumb, but here we are. I am fairly new to soldering and the wire Diagrams are a bit confusing, but I think I have the basics down. Except for one thing: Push Pull Pots!
I am attempting to do This Wiring Set Up Here to turn my volume knob into a series/parallel switch as well.
The problem is that I am not sure how to orient myself to the diagram. Should I be thinking of my switch pot like this:
With the knob facing up?
or
Like This, with the knob facing down?
I hope my question makes sense. I want the wires to end up soldered to the right terminals, I'm just a bit confused about what side is up.
Smaller side question: Can I solder the ground wire to the top of a push/Pull pot safely?
Last Question: Can I combine this style of a series/parallel switch with 50s style wiring like this? I like the brighter tone offered by the 50s style wiring of the cap, I just want to ensure that these two special wirings wont interfere with each other.
Thanks for any help you can give! I am new to this, but having a blast trying to figure it all out.
Have A Great Day!
Kelly Marshall
Re: A Quick Question About Guitar Wiring
Postby Kelly Marshall » Thu Feb 08, 2018 11:41 pm
I can't figure out how to edit my post, but I screwed up my pictures. The one for the PP Switch pointing down should be: https://imgur.com/K8iJuOM
Have A Great Day!
Kelly Marshall
Postby Gordon Bellerose » Fri Feb 09, 2018 1:25 am
I can answer at least one of your questions.
The wiring diagrams from Seymour Duncan, or any other site, always have the knob facing up, when it comes to push-pull controls.
Postby Kelly Marshall » Fri Feb 09, 2018 11:10 am
So if the knob is pointed up, wouldn't that mean that the default setting (with button depressed) would be parallel coils instead of series?
Have A Great Day!
Kelly Marshall
Postby Gordon Bellerose » Thu Mar 15, 2018 5:38 pm
Both are series in that drawing.
Series parallel humbuckers
Series/split/singles
Postby David King » Thu Mar 15, 2018 5:50 pm
Some push pull switches work in reverse, when the shaft is pushed in the switch commutator moves in towards the back of the pot. You can usually determine which kind you have by making a close examination of it's operation.
Yes soldering to the tab on the front edge of the top of the switch box is OK but don't dwell there or the plastic parts on the inside will melt.
