String distance from the fret board edge - Is there a term for this?
Postby Steve Sawyer » Wed Mar 22, 2017 9:12 pm
I'm starting a build journal so that I have all the specs, materials, hardware and techniques for each guitar I build.
Is there a term for the distance between the highest and lowest strings and the edge of the fretboard at the nut?
Re: String distance from the fret board edge - Is there a term for this?
Postby Peter Wilcox » Wed Mar 22, 2017 10:23 pm
From FretFind2D (a site you should have bookmarked for laying out fret boards) http://www.ekips.org/tools/guitar/fretfind2d/
"The fretboard overhang is the distance from the center of outer strings to edge of nut or bridge. For fretboards with multiple scale lengths this is calculated as delta x distance, distance measured along a line drawn perpendicular to the neck's midline. There are four input modes for overhang.
Equal:
you enter a single value and the overhang will be constant.
Nut & Bridge:
allows you to specify one overhang at the nut and another overhang at the bridge.
First & Last:
allows you to specify one overhang for the first string and another for the last string.
All:
you specify an overhang for all four locations separately."
Postby Steve Sawyer » Thu Mar 23, 2017 10:55 am
Thanks, Peter. I didn't have that site bookmarked, but I do now. "Fretboard Overhang" will do the trick.
