Where to find 74 LP Custom parts
Postby Jerrod Schober » Thu Jun 30, 2016 12:42 pm
Hi all,
I have a 74 LP custom, 20th anniversary, and need to replace the neck pick up mounting ring. The ones that are in production now are too thick and touch the strings when they're installed. Does anyone know where to find vintage guitar parts online or where I could find this part specifically or anything that would work for it? I've tried just google searching and haven't had much luck. Thanks!
-Jerrod
Jerrod Schober
Re: Where to find 74 LP Custom parts
Postby Dan Smith » Thu Jun 30, 2016 7:09 pm
If the rings are plastic, it seems like they could be sanded.
Dan Smith
Postby David King » Thu Jun 30, 2016 7:41 pm
Gibson "Historic spec" rings might fit better but I know for a fact that Gibson sanded them to fit the tops back in the day. They probably started with flush cut end nippers to get close and then a couple of strokes on a dummy body covered with sandpaper. They didn't waste a lot of time on this and the front rings are just bent over the top willy-nilly and screwed down.
If you want to go all the way and cost is no object then check out the "vintaged" parts from Japan from places like Montreux Guitars: http://www.montreuxguitars.com/datalist ... untingring
A google search for "M69 rings" will get you closer.
Postby Barry Daniels » Fri Jul 01, 2016 3:17 pm
It is normal for a luthier to replace the ring with a tall replacement and then it gets shaped down to fit the guitar and be at the right height for that particular instrument. The likelihood of finding one "off the shelf" that fits is unlikely. In other words, if your not able to do this yourself you should support your local luthier.
Postby Jerrod Schober » Sat Jul 02, 2016 2:54 am
Oh wow, is sanding something that an inexperienced guitar repairman could do, or would it be better to leave it to a professional?
Jerrod Schober
Postby Brian Evans » Sat Jul 02, 2016 11:04 am
If you can file your nails you can probably fit that part.
Postby David King » Sat Jul 02, 2016 5:22 pm
If you have access to a drum set you can sand on a kick drum side. Water heaters work well too. Typically the neck pickup ring is 30" radius in front, 15" in back while the bridge pickup is 15" radius in front and 20" in back.
