New Double Cut
New Double Cut
Postby Gordon Bellerose » Sun Jun 05, 2016 12:46 am
Here's my latest. It is a double cut Mahogany, with a fan shaped "insert" for lack of a better word.
It has SD Phat Cats installed. Very nice tone.
This one has a humbucker Tele bridge from GFS.
Maple Maple neck fingerboard.
Hope you like it.
This one shows the colors a bit better.
Re: New Double Cut
Postby Barry Daniels » Sun Jun 05, 2016 12:50 pm
Nice. I need to make a similar tapered lamination out of curly maple for a neck. Do you mind sharing your technique?
Re: New Double Cut
Postby Gordon Bellerose » Sun Jun 05, 2016 2:01 pm
First I measured the length and total angle I needed. In my case it was 12 degrees.
As you can see, the outside maple strips, and the center padauk strip are straight, so no effect on angle.
The 4 pieces that are angled are cut at 3 degrees each. I did this on the table saw, using my angle cutting jig.
After cutting them a bit thicker than needed I ran them through the "router table as a jointer" set up I use.
I used a push stick that is the full length of the pieces, so that they would not flex near the thin ends.
Glue up, was a few pieces at a time so that clamping was easier.
Re: New Double Cut
Postby Jason Rodgers » Sun Jun 05, 2016 2:02 pm
Cool! So that fan goes all the way through the body, not just a cap?
Re: New Double Cut
Postby Gordon Bellerose » Sun Jun 05, 2016 3:22 pm
Yes. The pieces are the thickness of the body.
Maybe I'll take a pic of the rear.
Re: New Double Cut
Postby Dan Smith » Mon Jun 06, 2016 7:17 pm
I like it!
Classic and refined.
Dan Smith
Re: New Double Cut
Postby Gordon Bellerose » Mon Jun 06, 2016 7:44 pm
Thanks fellas! I like this one myself. :-)
Re: New Double Cut
Postby Bob Francis » Mon Jun 06, 2016 8:14 pm
I like the dramatic contours too.
How thick is the body below the knobs?
Re: New Double Cut
Postby Gordon Bellerose » Mon Jun 06, 2016 8:51 pm
It's about 3/16 thick under the knobs. Hope that's what you're asking.
The body is a bit smaller than usual. It's only 12 inches wide inthe lower bout.
It's 1 5/8 thick.
Re: New Double Cut
Postby Bob Francis » Tue Jun 07, 2016 6:51 pm
Really nice!
thanks
Re: New Double Cut
Postby Brian Evans » Wed Jun 08, 2016 9:39 am
That, my friend, is enough to make me want to build a solid body guitar. That is exactly the kind of innovative artistry that draws me in. Good job well done!
Brian
Re: New Double Cut
Postby Eric Baack » Wed Jun 08, 2016 10:08 am
very nicely done!
Eric Baack
Re: New Double Cut
Postby Robert Smallwood » Mon Jun 27, 2016 6:11 pm
all smiles...
Robert Smallwood
Re: New Double Cut
Postby Gordon Bellerose » Mon Jun 27, 2016 11:36 pm
I promised to post a couple more pics, so here they are.
Body rear. The insert goes all the way through. Small tummy cut.
Here's the whole guitar on my deck.
One more pic of the headstock. I fully expect questions.
