I'm restoring an old EKO Ranger 12 String. It is missing the saddle which was adjustable height with 2 screws - similar to some modern gibson height adjustable saddles. This particular guitar has a small magnetic pick-up mounted in the end of the fretboard/soundhole (which looks factory fitted and there is an earth wire loose inside. So i presume that the earth wire was connected to the saddle and the saddle must have had a metallic element to provide effective earthing. I've looked for info on web and there are quite a few pics of this model but all are without the pickup and have 'bone' saddles
Questions: Has anyone seen a similar guitar with pick-up and can you advise saddle materials/construction?
Has anyone got any ideas on where I might find a replacement saddle and/or height screws?
Re: EKO Ranger 12 String
You could make a saddle from aluminum. Adjustable saddles steal away tone, so make one that's solidly mounted and non-adjustable. You can lay a pie of conductive copper foil with a wire soldered to it under the saddle and connect that to your ground (earth) and it'll be good to go.
Yeah, all the people who copied those Gibby adjustables didn't realize it was a poorly designed concept....I had, back in the day, inlaid the same wood and cut a traditional saddle slot. Saw probably 8 or 9 come through the shop after word got around.
- Bob Matthews
Hi Andrew, Brandoni Guitars here in the the UK have tons of spare parts for the Eko Ranger.
Have a browse thro their site or give them a call, they are very helpful.
http://www.brandoniguitars.co.uk/bridges.asp
Bob
Bob
