Compound head block?
Postby Bob Gramann » Thu Mar 15, 2018 1:08 pm
I usually match the headblock wood to the neck wood (from the same tree when I can). I'm getting ready to construct a classical guitar with a walnut neck and find that I don't have a block of seasoned walnut large enough to be a one-piece headblock. So I want to glue a 3/4" piece to the bottom of the headblock (this piece will also be carved to make the Spanish foot) to make the headblock tall enough. It will be a bolt-on neck. Will this cause me any problems in the long future? (I plan to use 315g hot hide glue).
I am constructing the guitar with all-USA sourced woods. If the compound walnut block won't work, I will either need to use a cherry block with the walnut neck or a cherry block and neck, or I will have to get some more walnut and wait until it acclimates to my shop.
Re: Compound head block?
Postby Randolph Rhett » Thu Mar 15, 2018 1:15 pm
I've never before heard of needing to match the neckblock to the neck wood. I am assuming there are some benefits, but I don't believe for a moment that it will cause you any trouble assuming both are from stable well seasoned stock.
Randolph Rhett
Postby Bryan Bear » Thu Mar 15, 2018 1:25 pm
I'm far from an expert but I agree with Randolph on both counts. I think any way you go will be fine. I have used stacked up heel blocks before even using spruce with 5 layers of alternating grain direction stacked up (bolt on neck) with no problem.
Users browsing this forum: Bing [Bot] and 6 guests
