Pickguard adhesive
Pickguard adhesive
Postby Doug Shaker » Sun Dec 31, 2017 11:43 pm
I'm close to done with a multiscale baritone and, with the player for whom it is intended, I should probably put on a pickguard. I bought a sheet of "pickguard adhesive" from LMI. What I received was a sheet of 3M 467MP adhesive film. One removes one backing layer, attaches it to the pickguard, trims it to size, removes the other backing layer, and attaches the pickguard to the guitar. All well and good and very convenient. A thin, strong, transparent adhesive.
However, as I look as the datasheet for the adhesive, I can find no way to remove the pickguard later. This worries me. Eventually this pickguard will go the way of all flesh and some repair guy is going to have to figure out how to remove that pickguard. If I don't know how to do it now, how's he or she going to be able to do it in ten or twenty years (if this guitar lives that long and it's still wanted). I'd hate to think of the repair person trying to pry it off and gouging the spruce underneath.
Any advice or thoughts on a good way to attach a pickguard?
-Doug Shaker
Doug Shaker
Re: Pickguard adhesive
Postby Joshua Levin-Epstein » Mon Jan 01, 2018 6:49 am
The transfer adhesive is a good way and the industry standard (though being industry standard is not, in itself, proof of infallibility).
A pick guard so installed is removable by judicious moderate heat and naptha. I've had to reaffix several pick guards where the transfer adhesive has given up on its own.
Not that you haven't already spent enough time on your build, but maybe you'd feel better if you included a brief description of your building techniques (adhesives and finish used, where not to put a strap button etc.) with the instrument.
This might help the future fixer (or owner) who assumes the best way to remove the pick guard (or anything else) is with a belt sander.
http://www.frets.com/FretsPages/Luthier ... guard.html
Postby Clay Schaeffer » Mon Jan 15, 2018 9:49 am
"A pick guard so installed is removable by judicious moderate heat and naptha."
If you are using naphtha, definitely "moderate" the heat - it is rather flammable.
Postby Bob Gleason » Fri Jan 19, 2018 11:47 am
I've used that adhesive for many years. It is available on Amazon in lots of sizes. Extremely useful around the shop wherever a thin strong adhesive is needed. I use it a lot for holding inlay pieces and for applying labels to instruments. It never lets go, at least not in the 35+ years I've used it.
Bob Gleason
