Reject wood guitar? Prototype?
Postby Matthew Lau » Tue Oct 31, 2017 4:33 pm
I have been ashamed of guitar #2 (LMI classical guitar kit with Euro Spruce and Camatillo Rosewood).
The wood did no wrong.
However, I botched the job, insulting the wood.
I'd like to reuse the back/sides for a prototype classical guitar.
Have you guys ever taken apart "reject" guitars and used them for something else?
On my end, I'd like to do honor to the wood.
But I'm not sure if I should start anew?
Matthew Lau
Re: Reject wood guitar? Prototype?
Postby Bryan Bear » Tue Oct 31, 2017 4:59 pm
It's hard to say without really knowing what was wrong with the guitar and what the prototype involves but my gut reaction is to say, start anew. It you are prototyping a new design you should be starting from scratch so you avoid the temptation to make the design/execution fit the materials or their situation.
Postby Barry Daniels » Tue Oct 31, 2017 6:02 pm
A professional guitarist that I respected came to me to make a guitar. He wanted my to reuse parts from an old Yamaha to build it. I had to politely show him the door. Recycling is not appropriate to guitar building.
Postby Bill Raymond » Wed Nov 01, 2017 1:42 am
Can't say I've done it, but I don't see any reason not to recycle where it may be appropriate. It really does depend on what went wrong with your #2 and the use of any wood you can salvage from it.
Bill Raymond
Postby Trevor Gore » Wed Nov 01, 2017 8:04 am
Professional guitar makers quite often have a "test mule" guitar or two, which new ideas are tested out on. I have a couple of guitars of different types that have had multiple tops on. If you do a decent job, very few people would be able to tell that a top (or back) had been changed. Here's one I changed recently. A few weeks ago it had a spruce top on...
This one was done as a "drop in" replacement top, keeping the original bindings.
Trevor Gore
Postby Clay Schaeffer » Wed Nov 01, 2017 12:38 pm
It would be a shame to waste good wood so why not? If you can make it do want you want it to - go for it!
Several people on the forum have retopped cheap guitars to make them sound better, and even putting a new top on a high quality instrument is not unheard of.
Postby Doug Shaker » Sat Nov 04, 2017 11:06 am
I don't know you will get a good guitar out of it, but I'll bet you learn alot.
-Doug Shaker
Doug Shaker
Postby Brian Evans » Sat Nov 04, 2017 11:32 am
I very much appreciate the idea of respecting the wood, so I might very well reuse wood that I had already put to one purpose. To me, using reclaimed wood is part of that - using wood that spent a century as beams in a barn, for example, or spent a century on the bottom of a river. Mostly what goes wrong with an instrument for me is the finishing. I've routed off bindings and sanded back finishes to start again, I just do the best job I can. The decision would rest on the wood, and what I needed to do to it.
Postby Chris Reed » Sat Nov 04, 2017 6:15 pm
I recycled the body of a 70s Japanese dreadnaught into a pear-shaped tenor guitar with a new top made of yew. That turned out fine.
Chris Reed
Postby Matthew Lau » Mon Nov 06, 2017 4:59 pm
That's gorgeous!
Your test mule looks nicer than some of my finished guitars.
I'll probably try to salvage as much of the guitar wood as possible (back/sides) and try to refinish.
In teh worse case scenario, I'll paint it black.
Trevor Gore wrote:Professional guitar makers quite often have a "test mule" guitar or two, which new ideas are tested out on. I have a couple of guitars of different types that have had multiple tops on. If you do a decent job, very few people would be able to tell that a top (or back) had been changed. Here's one I changed recently. A few weeks ago it had a spruce top on...
Matthew Lau
Postby Matthew Lau » Mon Nov 06, 2017 6:29 pm
btw Trevor, one of these day's I need to get your book.
Can i get it autographed too?
Matthew Lau
Postby Trevor Gore » Tue Nov 07, 2017 7:39 am
Matthew Lau wrote:That's gorgeous!
Thanks!
Matthew Lau wrote:In teh worse case scenario, I'll paint it black.
Black paint is not really an easy way out. Most of my finishes are clear, so I asked a few guitar makers who do a lot more painting than me about how to go about a black finish. The unanimous advice was "don't do it"! They had a point, but I did it anyway. It's not easy. Lots of masking and scraping then reverse masking to level the different finish thicknesses, etc, etc. And black is not black. It's a gazillion different shades of grey!
Matthew Lau wrote:btw Trevor, one of these day's I need to get your book.
Sure. Just remind me when you place the order.
Trevor Gore
Postby Matthew Lau » Tue Nov 07, 2017 8:06 pm
Dang! You have a gorgeous piano black.
I was just thinking of experimenting with black shellac.
More likely, I'll try to strip off the old shellac and carefully tackle the area to re-french polish the body.
Matthew Lau
Postby Trevor Gore » Tue Nov 07, 2017 11:02 pm
Matthew Lau wrote:I was just thinking of experimenting with black shellac...
I did the one above in nitro. Just getting the pigment here was a major hassle. I got some just before reaching for a rattle can...
Trevor Gore
Postby Randolph Rhett » Wed Nov 08, 2017 2:07 am
At this point I'm tripping all over my "test mules". They seemingly outnumber the successes!! I just can't bring myself to throw even failed tops away, but I don't know what I think I'm going to do with them. For example, I have some cutaway sides that were just too ugly to actually use on a "real" guitar. So I split them into two 1.75" rims for a double cutaway thinline guitar. Only I realized that I would need a neck that joined at the 17th fret, not 14, or it would look silly. So I can't use any of my standard necks. Do I make a new neck for these salvaged sides? And none of my reject tops or backs are double cutaway, so I'd be making those new. And the neck block, tail block, and linings will all have to be new...
The point is I never actually find a use for these rejects. But they sit around my shop nonetheless.
Randolph Rhett
Postby Clay Schaeffer » Thu Nov 09, 2017 8:51 pm
"The point is I never actually find a use for these rejects. But they sit around my shop nonetheless."
Sometimes you have to look at them as "raw material" rather than as something you have time invested in. Your ugly double cutaway sides might be good for binding material or re-bent for ukulele sides.
I did a black topped guitar. One of the most difficult parts was photographing it.
Postby Matthew Lau » Fri Nov 10, 2017 11:39 pm
Ha.
I'll happily take one of your test mules off your hands!
When I was traveling for work like a hobo, I'd be stuck in lonely 1 star motels in the middle of nowhere.
When I was traveling for implant training, I'd be stuck in lonely 4 star hotels wishing for a guitar.
My goal for the test mule is:
1. Experiment with stuff without shame--- hmmm, change the bracing on the back? Okay, pop that off with hot water!
2. Be playable without any worries of getting it dinged up.
I had a Korean roommate who was a total asshole. He'd grab my french polished guitar without asking, take a pick, and ding the hell out of it before I'd catch him. Later, he went to Hopkins to do Oral Surgery.
For that asshole who thinks he's being friendly, that flamenco guy who has one too many drinks, that neophyte wearing spiked leather that has no idea of how to treasure a guitar....it'd be nice to have a sacrificial lamb to protect the others.
-Matt
ps. Clay, could I bug you for pictures of your travel guitar?
I'd love to make one with my test mule.
Matthew Lau
Postby Clay Schaeffer » Sat Nov 11, 2017 9:42 am
Hi Matthew,
I'll try to post a few pics.
I make them in various models - usually Martin clones. Here is a Dred and a double O. Personally I like the size 1 (not shown).
(P.S. - I also made the picnic table they are sitting on out of Corian scrap.)
Postby Clay Schaeffer » Sat Nov 11, 2017 10:05 am
The neck is attached with a single socket head cap screw ( machine bolt) placed in the lower part of the heel which has been reinforced with a metal insert. The block in the body has a T nut for the bolt to screw into (not visible) and two pins mounted higher up to keep alignment. The truss rod is inset into the neck. I started making a neck pocket that is slightly more than the depth of the sides. It allows the fret board to be cut between the 12th and 13th fret and if angled back some can be used to set the action by using a shims (washers) around the bolt.
Postby Clay Schaeffer » Sat Nov 11, 2017 10:19 am
The body has a "port" in the bottom that is closed by a brace on the inside and a bolt run through the strap button. The end block is wide enough to include the port and has reinforcements glued behind it that also cradle the neck when it is inserted into the body. The machine bolt in the neck is reversed and screws into a T nut inserted into the upper reinforcement. The neck block (not shown) has a pocket that captures the peghead and keeps it secured at the upper body.
Next
