Tuners for 12 string
I just got my first commission for a 12 string. Any suggestions regarding tuners?
Thanks in advance
Steve
Thanks in advance
Steve
Re: Tuners for 12 string
Many years ago when I built my first and only 12-string, I used the Gotoh mini-tuners. I was bery satisfied.
I've used mini-Grovers with Martin spacing and think the washers are ugly (tuners work fine however). StewMac golden era repro are OK for a slot head - for a while they were about the only thing available. Holes need to be drilled very carefully.
fwiw, I made simple but very effective drilling jigs for both of those guitars. Here it the one for the paddle head
The key stock lines up with the outside edge of the headstock, clamp it on and drill the holes. Obviously it wouldn't work for a curved headstock. If you are going to do something like that you probably should lay it out carefully - it is real easy to have strings fouling tuner posts.
Here's the slot head
I'm going to add one more comment about 12 strings, Steve, that has nothing to do with tuners., Design them to fit available cases if possible - both of mine required custom (expensive, long delivery) cases and Leo Kottke has a wonderful story on a dvd about cutting the end off a headstock to get it to fit a case....
Thanks Freeman, much appreciated.
Steve
Steve
All have made good points, but I'm jumping in anyway. My first "good" guitar was a 12-string and it was a chore to restring it. Not as bad as a Rickenbacker or d35-12, but still a chore. If I were to build a 12 string, I'd consider a machine with safety posts, like Fender used. This used to mean Fender repros (left and right hand) but these are probably not aesthetically adequate for a benchmade guitar. I did a quick look at the Kluson catalog from WD and there are some pretty nice machines with these slotted posts. These will no doubt be much better than those old Klusons which begged to be replaced.
Another consideration is weight. I thought Guild was pretty cool when they started putting Schallers on their 12s until I found the balance/weight unpleasant and saw lots of broken pegheads. The mini machines mitigate this to some extent.
Just my 12 cents.
Just my 12 cents.
I've used the Stewmac 'Golden Age' machines, and they work well. I'm no enamored of the look on a new gutiar, though. I keep meaning to bug them about coming out with Waverly 12-string sets, using the same post spacing.
" If I were to build a 12 string, I'd consider a machine with safety posts, like Fender used. This used to mean Fender repros (left and right hand)"
I used those on a travel harp guitar. I liked the clean appearance and light weight. The closer spacing helps reduce the length of the peghead needed.
Thanks Joshua, not sure I understand the value of slotted tuners.
Steve
Steve
I have been frustrated with the selection of 12 string tuners. There just isn't much out there. I would like good six-on-a-strip tuners, for paddle head pegheads. And on top of that, I'd like there to be a matching six string set. This would allow for mixing and matching for guitars with less than 12 strings, such as the nine-strings that I build.
I have used the Waverly clones sold by Guitar Fetish. They work pretty well for 12 strings.
The slotted posts have holes down the center of the post. You cut the string a bit beyond the machine, stick the end in the hole and wrap. It's fast, clean and works well. And the newer machines of this type are much improved over the "vintage" ones.
Google "Kluson slotted machine heads" and you'll find some examples.
