Hello All,
I have decided to stick with the vertical model for my binding cutter machine and thus the horizontal one is up for grabs. I built this from MDF to the specs from the Blues Creek instructions. The telescoping mechanisms operate smoothly as does the lazy Susan allowing a full range of motion. The platform for the router was based on a Porter Cable laminate router but you can either adjust yours to fit or simply make another to suite. You'll also need a small ring or collar for it. I added a drawer for the bits and bearings as well.
I'm asking $200 plus shipping. It weighs xx lbs. I am open to trades as materials and tools are always needed.
Thank you,
DJ
Binding Cutting Machine
Forum rules
- Attachments
- oldbind2.jpg (23.8 KiB) Viewed 5016 times
- oldbind1.jpg (22.19 KiB) Viewed 5016 times
Re: Binding Cutting Machine
The binding machine has found new home. Thank you!
