Aqua Coat Grain Filler
Postby John Clifford » Sun Dec 31, 2017 7:24 pm
I know there was a short thread on this back in 2012, but I'd like to hear from anyone else who has had success with this product. I really want to like it, but after several tries, I'm just frustrated with it. Yes, it does eventually sort of fill the grain, but I have to put on like 10 coats with light sanding in between to get anywhere. It ends up being more work than the old pumice, shellac and wood dust method (which is a lot of work). Am I doing something wrong? If it works for you, what are you doing?
Thanks.
John Clifford
Re: Aqua Coat Grain Filler
Postby Bob Gramann » Sun Dec 31, 2017 8:56 pm
I’ve tried it a few times. I end up going back to pumice each time.
Postby Paul Rhoney » Mon Jan 01, 2018 1:32 pm
I've tried it and had similar experiences. Gork's GoodFilla is pretty much the only grain filler I ever use anymore these days, and they now offer a clear.
Paul Rhoney
Postby John Clifford » Mon Jan 01, 2018 2:44 pm
Paul, tell me about the Gork's GoodFilla. How many coats does it take you to fill a medium grain wood like mahogany or sapelle? Does it sand well?
John Clifford
Postby Paul Rhoney » Thu Jan 04, 2018 1:04 pm
My application process starts with a wash coat of whatever type you're using, then one of the Gork's opaque grain fillers, wipe the excess off with a damp paper towel, then another wash coat (a little heavier this time), then the clear grain filler, wipe again, then sealer until it's level. So even though the Gork's sands very easily, I never actually do that. Unless it's been too long for my wash coat to bond with the next coat without a scuff.
The clear Gork's is great but is only really useful for shallow grain. It goes on white and if too much of it is packed into a deep pore, it stays white instead of turning clear when you apply finish over it.
Paul Rhoney
Postby John Clifford » Thu Jan 04, 2018 5:59 pm
Thanks Paul.
John Clifford
Return to Glues and Finishes
