Turquoise Stain
Turquoise Stain
Postby Gordon Bellerose » Fri May 26, 2017 4:23 pm
I want to do a blue burst guitar, that starts with a turquoise blue in the center.
I'm not sure I can get the right color by simply diluting the blue stain I have.
Does anyone know of good light blue water-base stain. I do want it to be transparent also.
Re: Turquoise Stain
Postby Mark Swanson » Fri May 26, 2017 6:42 pm
Use a lacquer tint or dye, and not a stain. With colors like that it is best to tint the finish.
Re: Turquoise Stain
Postby Gordon Bellerose » Fri May 26, 2017 9:28 pm
Mark.
I usually do mix the color into water base lacquer. Do you think I will be able to get a light enough blue to look turquoise?
Of course I will practice on scrap. :-)
Re: Turquoise Stain
Postby Mark Swanson » Fri May 26, 2017 11:59 pm
I would think so...I have sprayed blue tinted lacquer and the first thin coats looked like that. You will need to start out with a very light colored wood base for sure, white maple or something.
Re: Turquoise Stain
Postby Peter Wilcox » Sat May 27, 2017 3:04 am
I've used watercolor paints (the kind that comes in tubes.) They are transparent, and I imagine the good quality ones are color fast.
Re: Turquoise Stain
Postby David King » Sat May 27, 2017 8:33 am
Turquoise is going to require some yellow wood or a bit of yellow dye in the center section isn't it? There are several blues and some would get you a lot closer to turquoise than others. Solar-lux sea blue is going to get there, cobalt or royal blue isn't.
Re: Turquoise Stain
Postby Clay Schaeffer » Sat May 27, 2017 8:34 am
Mohawk makes a blue dye stain (ultra penetrating stain) that could be mixed with the green dye stain to pull whichever turquoise you might want.
Re: Turquoise Stain
Postby Gordon Bellerose » Sat May 27, 2017 11:41 am
Yeah, I've been thinking about this for a while now, and that is why I am asking.
Yellow into blue makes green. I've done that in one of my builds prior to this. A single drop of yellow can turn blue into a really green color.
I'm thinking a bit of white may have to go into the blue, but I only have opaque white, and I don't think white is available in a transparent stain/dye.
The wood I am working with is ash, and a fairly white ash at that. It has some beautiful grain in it, thus the wish for transparency.
I may simply go with a different deeper royal blue, if I can't satisfy my craving for turquoise.
Re: Turquoise Stain
Postby Barry Daniels » Sat May 27, 2017 12:35 pm
I forget the details, but I seem to remember that transparent dyes combine differently than opaque colors.
Edit: Look up "additive and subtractive color mixing" to see the differences.
Second Edit: I found an online, interactive additive color mixing wheel. When you add green and blue you get turquoise. http://www.physics-chemistry-interactive-flash-animation.com/optics_interactive/additive_color_model_mixing_synthesis.htm
Re: Turquoise Stain
Postby Peter Wilcox » Sat May 27, 2017 2:36 pm
This shows the result of pthalo blue applied to the central spalted area which had a slightly yellow tint; the result looks pretty close to turquoise to me.
Here's pics of the bare wood, and after application of the watercolor but before lacquer.
viewtopic.php?f=4&t=4544#p44275
Re: Turquoise Stain
Postby Bob Francis » Sun May 28, 2017 11:21 am
Peter Wilcox wrote:This shows the result of pthalo blue applied to the central spalted area which had a slightly yellow tint; the result looks pretty close to turquoise to me.
Wow!
Re: Turquoise Stain
Postby Clay Schaeffer » Sat Jun 10, 2017 6:41 pm
Wow!+
Re: Turquoise Stain
Postby Beate Ritzert » Sat Jun 10, 2017 6:55 pm
Wow++
Barry Daniels wrote:Edit: Look up "additive and subtractive color mixing" to see the differences.
But we will not have additive mixing unless we use colorful light. When we stain or use tinted laquer, mixing of colors will always be substractive.
Beate Ritzert
Re: Turquoise Stain
Postby Barry Daniels » Sun Jun 11, 2017 10:56 am
Beate, you may be right about that, but when using tinted lacquers things don't always work out like expected, from my experience.
Re: Turquoise Stain
Postby Randolph Rhett » Sun Jun 11, 2017 2:17 pm
Here is a guy that does some nice stuff with just wipe on leather dyes:
https://youtu.be/N45O5K3ntik
https://youtu.be/MiJoGUQckwk
Randolph Rhett
Re: Turquoise Stain
Postby Gordon Bellerose » Mon Jun 12, 2017 12:03 am
Thanks for all the replies. A lot of information coming from the members!
I am looking into the leather dyes. I've been watching Big D guitars for a while now. Thanks for the reminder.
I have wiped on color in the past using alcohol, and water both, as a medium. Water spreads nicer, but raises the grain more. Alcohol dries very quickly, so you have to work quickly.
Peter Wilcox. The thalo blue dye. What kind is it, and where did you get it?
Re: Turquoise Stain
Postby Peter Wilcox » Mon Jun 12, 2017 2:27 am
Gordon, it's from this watercolor set I bought about 15 years ago at Michaels: https://www.amazon.com/Reeves-Assorted- ... d_sbs_hg_2
But as you can see from my pic of the guitar, different parts of the wood took the color quite differently - the turquoise color came up on the spalted wood that initially had a yellow tint to it. I wiped exactly the same mixture (pthalo blue and a little black, diluted with water) on the whole top - the rest of the wood absorbed the black color too, and the blue is also much more "blue." If you try this you will probably have to add some yellow and possibly green also. A nice thing about watercolor sets is that you have many possibilities. If I decide on a mixture of colors I'm careful to mix enough do do the whole job, because I know I'll never be able to duplicate it exactly no matter how carefully I measure.
Re: Turquoise Stain
Postby Gordon Bellerose » Tue Jun 13, 2017 1:50 pm
Peter,
You said that these are transparent, correct?
Re: Turquoise Stain
Postby Peter Wilcox » Tue Jun 13, 2017 10:10 pm
Gordon Bellerose wrote:Peter,
Some are transparent in varying degrees, some are opaque. In general, I think most watercolors can be considered transparent because they are diluted significantly in use (in washes anyway.)
Here is a brief list of some transparent colors:
http://www.artguildstore.com/uploads/2/ ... y_list.pdf
Here's some more extensive info on the subject (page 10 for transparency or opaque):
http://www.winsornewton.com/assets/Leaf ... nglish.pdf
As we always say, test on scrap!
Return to Glues and Finishes
cron
