Quality Spray Gun Recommendations Needed
Andrew McSpadden
Post by Andrew McSpadden »
I am spraying Enduro-Var and I have HAD IT with my HF door jam guns for spraying bursts. I have $200 to spend. Recommendations?
Todd Stock
Re: Quality Spray Gun Recommendations Needed
Post by Todd Stock »
A used SATA Mini-Jet 3 if you can find one - they come up on Craigslist once in a while, and a rebuild kit is not expensive. O for a new gun, try a mid-priced gun like an Asturo WB...about $200 and 3 com @ 40 psi. The Asturo is all stainless, which is the reason for the 'WB' moniker - no corrosion of aluminum or brass/bronze with waterbased stuff like Enduro-Var.
http://www.spraygunworld.com/products/A ... 20Cup.html
FWIW, I seldom spray with conversion guns anymore - the Fiji MM-4 with T-75G will handle everything from airbrush-like touchups to full-scale stuff like boats and airplanes. Just out of your price range by $600 or so.
Post by Chuck Tweedy »
Andrew, I use a cheap HPLV gun for EV - with SS internals. I'm sure the guns Todd reccommends are good.
Be sure to use a 1mm tip (as spec'ed by General). And filter the finish - and you should good to go.
Andrew McSpadden
I bought the Asturo! I will post my review in a week or two. Thanks for the Recommendations!
