Dust collectors to stay away from?
Re: Dust collectors to stay away from?
Thanks, yea, I am a mask junkee, and eyewear also, just stepping in the shop I have at least a basic dust mask on. Respirator when I do serious work.
Quick n somewhat clean method for filtering shop vacs:
Run a bit of straight pipe out the exhaust,pull an old sock over it and duct tape. Pull another half over that and tape.Pull another half over that and tape. Any more seem to load the motor. Takes care of fine particulate nicely.Change frequently.
Emergency inner filter for shop vac: cut off t-shirt sleeve pulls over filter frame and duct tapes nicely. Change frequently if you just can't make it to Wal-Mart for a proper one.
Mad Max approved.
Mad Max approved.
Just note that once you start running dust through the motor, you will never get it clean enough to use in an indoor breathing space again.
I have a hepa filter on my shop-vac, and a 5 gallon 'cyclone' pre-dust collector, so there is not a lot going through the exhaust.
Tom, It sounds like you have a good handle on the shop vac's inherent weaknesses. I would recommend that you consider also using the yellow "sheetrock dust" shop vac bags. They will save you a lot of time keeping the hepa filter clean and will insure that it lasts indefinitely.
