no biggie: a good inexpensive glue syringe
Postby Bob Hammond » Tue Oct 17, 2017 11:24 am
Hi,
Here's an item I picked up at the Kroger supermarket. It's a 30ml turkey injector syringe that has several features to recommend it. The barrel & plunger are made of polycarbonate, The needle & hub are standared stainless steel Luer-Lok fittings (medical style & grade). It can be fully disassembled for cleaning, including removing the luer fitting from the barrel. It would be perfect for hot hide or regular glues. I would not soak it in organic solvents, but a quick wipedown shouldn't hurt it. It might be a good idea to bore out the Luer fitting a bit too. And all that for $2.50.
sorry for blur!
Bob Hammond
Re: no biggie: a good inexpensive glue syringe
Postby Paul Breen » Tue Oct 17, 2017 1:14 pm
Here is my rig, pictured with a few bent Brass tubes and the pipettes I use. A stewmac syringe, plastic and Brass tubing from the the hardware store and a regular hypo needle. The tubing I.D.'s are 1/8" and the hypo needles just by luck happened to be a snug fit on the Brass tubing. I just bend lengths of the Brass tubing for each project and make new ones as needed. Great for hard to reach braces or inside small access holes, ect.. If the hypo needle leaks a bit on the end of the Brass tubing, some electrical tape wrapped tightly fixes the problem. To keep hide glue hot in the rig, I place the loaded injector rig on a piece of Black plastic laminate with an infra Red lamp over it. Shiny objects will not heat under Infra Red light but the Black laminate does and keeps things warmed up.
Paul Breen
Postby Matthew Lau » Fri Oct 27, 2017 2:43 pm
If any of you are related to a MD or dentist, we get a box of 50 for about $20.
Matthew Lau
Postby Bob Francis » Fri Oct 27, 2017 7:11 pm
Matthew Lau wrote:If any of you are related to a MD or dentist, we get a box of 50 for about $20.
That's a great idea. I was going to Tractor Supply to see if they had anything for livestock.
Return to Tools and Jigs
