LMI wood
Veneer Info.
Veneer Info.
Postby Robert Freemond » Tue Dec 25, 2018 3:59 pm
I've been looking for black veneer for neck laminations & there are a lot of Solid wood reconstituted dyed veneers.
What is meant by reconstituted? & is it strong enough for a laminated neck?
Robert Freemond
Re: Veneer Info.
Postby Clay Schaeffer » Wed Dec 26, 2018 11:07 am
Reconstituted wood products include OSB, MDF, particle board, flakeboard, fiberboard, waferboard, and other products made from smaller pieces of wood glued back together. I might consider it for a peghead veneer but would be reluctant to use it for a stressed joint. YMMV
Re: Veneer Info.
Postby Robert Freemond » Wed Dec 26, 2018 1:12 pm
Thanks, Clay, I guess I should have figured that out for myself since all of the reconstituted wood is dyed - No grain.
Robert Freemond
Re: Veneer Info.
Postby Rich McCrea » Tue Jan 08, 2019 6:18 pm
Try Spectraply a Dyed birch veneer by Cousineau wood products
Rich McCrea
Re: Veneer Info.
Postby Robert Freemond » Tue Jan 08, 2019 8:30 pm
Thanks Rich, I'll do that right now.
Robert Freemond
Re: Veneer Info.
Postby Rich McCrea » Wed Jan 09, 2019 12:49 pm
The spectraply is normally used for laminated rifle stocks, I started a semi hollow tele out of it. I also brought in some of their Dymalux as a fretboard substitute . Initial tests show promise.
Here's the Tele
Rich McCrea
Re: Veneer Info.
Postby Robert Freemond » Thu Jan 10, 2019 8:11 pm
So The whole body is laminated?
Robert Freemond
Re: Veneer Info.
Postby Rich McCrea » Fri Jan 11, 2019 12:50 am
Yes It was a 2 " slab 24"x 36" I got from a now defunct business. I cut a 1/4 " cap off , hollowed out the body like a thinline and replaced the cap. It had to be planed on a bias or it would show only one color
Rich McCrea
Re: Veneer Info.
Postby David King » Tue Jan 15, 2019 1:53 pm
There's no indication on the site that Cousineau will sell individual dyed veneer sheets, only their finished product.
Re: Veneer Info.
Postby Rich McCrea » Wed Jan 16, 2019 11:08 am
On their home page
click on spectraply
click on panels
3/4' to 3 " thick
Rich McCrea
Re: Veneer Info.
Postby Robert Freemond » Wed Jan 16, 2019 7:57 pm
I'm looking for approx. .060 black maple or similar.
Robert Freemond
Re: Veneer Info.
Postby Barry Daniels » Wed Jan 16, 2019 9:02 pm
Certainly wood carries thicker veneers and they have some black dyed poplar that is about .041 thick. I bought some 1/16" thick veneer from them before and it was excellent quality.
https://www.certainlywood.com/woodmenu2.php?category=Special%20Thickness%20Veneers
Re: Veneer Info.
Postby Robert Freemond » Fri Jan 18, 2019 7:57 pm
Thanks, Berry
Robert Freemond
