LMI wood
ABS binding ?
ABS binding ?
Postby Robert Freemond » Fri Jun 09, 2017 3:25 pm
In an attempt to do everything in house I was thinking of making my own ABS binding. I know that ABS pipe is porous, but sheet stock is available & so is Vinyl.
I'm wondering if anyone here has used either with good results.
Robert Freemond
Re: ABS binding ?
Postby Clay Schaeffer » Fri Jun 09, 2017 7:48 pm
I use PVC edge banding material. It comes in various thicknesses (1,2,and 3 mm generally) and widths and a million different colors (I use white and black). I bought a roll of 1 inch wide stuff (2mm thick?) and rip it to width to make plastic bindings. It is cheap and works as well as the plastic bindings the luthier shops sell. Some distributors sell thick wood edgebanding, but I haven't used any of that on guitars (only cabinets) but it might also be worth looking into.
Re: ABS binding ?
Postby Steve Sawyer » Fri Jun 09, 2017 11:22 pm
Clay Schaeffer wrote:I use PVC edge banding material. It comes in various thicknesses (1,2,and 3 mm generally) and widths and a million different colors
Clay - I've been planning my next build, and was wondering if I could find some colored binding /purfling. Can you share your source for that?
Re: ABS binding ?
Postby Clay Schaeffer » Sat Jun 10, 2017 9:57 am
Hi Steve,
I usually order mine (infrequently) through a local cabinet shop, and if you only need a few feet of it you may want to see if they have what you want in stock. Full rolls can be ordered online - google PVC edgebanding and a number of suppliers will come up. The rolls are about 300 ft long (approx. $70 to$90) and can make 600 to 900 feet of binding depending on how you cut it. I rip it to width on a table saw. A roll will do a lot of guitars! Unless you are a factory, 1 roll is probably a lifetime supply.
I need to order black as I have run out. As someone said about ebony after binding a guitar with it - It looks just like black plastic!
Here is a link to a seller I found with a quick google search (I've never ordered from them):
http://wholesalecabinetcomponents.com/i ... /list2.htm
Re: ABS binding ?
Postby Steve Sawyer » Sat Jun 10, 2017 10:21 am
Thanks, Clay. I'm going to be visiting a cabinet shop this week and I'll ask. I'm looking for enough in green to match/complement a dye job for ONE guitar, so 300' would be over-kill!
cron
