MMK 53 p/u
James Ansara
MMK 53 p/u
Post by James Ansara »
Hi, I have a pair of MMK 53 p/u that have a slug coil and a slotted adjustable pole piece coil, the p/u have gold plated covers. I have not tried them but I'm considering putting them in a '70s Les Paul. Does anyone here know how these would compare to the stock p/u of a Les Paul standard?
Thanks
James
Greg Robinson
Re: MMK 53 p/u
Post by Greg Robinson »
No idea James, but if you want a quick and dirty way to try it out, connect the pickup up to a jack, and hold it above the strings of your LP while strumming. You can make a jig to hold it in place if you want, but I've always found the rough and ready approach to give me a good enough idea.
James Ansara
Re: MMK 53 p/u
Greg Robinson wrote:No idea James, but if you want a quick and dirty way to try it out, connect the pickup up to a jack, and hold it above the strings of your LP while strumming. You can make a jig to hold it in place if you want, but I've always found the rough and ready approach to give me a good enough idea.
Thanks Greg , I don't want to take the p/u s out just to have to put them back in , I'll try that.
James
Return to “Electronics”
