50mm Spacing Saddles Needed for Hardtail Harmony Marquis
Kenny Lewitt
Post by Kenny Lewitt »
G'day,,, Me being new to this board, if I should be posting this elsewhere, kindly advise I just picked up an early Harmony Marquis guitar that has a hardtail bridge, but the strings are 'through body' mounted. Though my hardtail plate is 50mm at the intonation screws, the saddles are all squeezed together, and at the point where the strings hit the saddles, it's closer to 52, 53mm. So, I need some steel saddles that are no more than 50mm from center of the Low E saddle to the center of the Low e.
Many thanks in advance.
Be well all~
Kenny
Reason: Spelling mistake in title
Jim McConkey
Re: 50mm Spacing Saddles Needed for Hardtail Harmony Marquis
Post by Jim McConkey »
Welcome to the Forum, Kenny! This should probably be in Repairs, but I will wait to move the discussion until after you have seen it.
